oil pan instant gasket stuff
Old Nov 2, 2009 | 11:24 AM
kersh4w's Avatar
Hit & Run Magnet
im working on an e30 with my friend. he had a little accident so we had to replace a lot of things. one of them was the oil pain, if you've ever worked on e30s, you know. he cracked the oil pan when it hit steering rack. we put a replacement in there, but now the car is leaking oil. he said maybe we didn't torque it down enough. but i think that's impossible. those TINY 10mm bolts cant be rated for more than 30ft/lbs and they were very easy to take off. i think the CORK BOARD of a gasket is not sealing properly. and im serious when i say its a cork board....
so, anybody know any make your own gasket sealer goop things that actually work really well?
tia.
Old Nov 2, 2009 | 12:01 PM
Huey52's Avatar
Registered Zoom Zoomer
There's nothing inherently bad with using a cork gasket, they've been used for years and I prefer them over some of the [literally] paper thin gaskets used on other cars. But they can all be improved with sealant.
Loctite Ready Gasket Sealant http://auto.sears.com/LOCTITE-READY-...ductId=2019807
Old Nov 2, 2009 | 01:21 PM
kersh4w's Avatar
Hit & Run Magnet
thanks man.
Old Nov 2, 2009 | 01:36 PM
EDZRIDE's Avatar
2005 White GT
This works great: http://www.gasgacinch.com/
Old Nov 2, 2009 | 04:38 PM
CyberPitz's Avatar
Huge hole is huge
Epoxy!
Wait........
Old Nov 2, 2009 | 07:12 PM
Grey RTV works great....same stuff that you would use on your 8
RevMeHarder
Jun 1, 2026 02:30 PM
DVerdeyen
Sep 13, 2015 11:19 AM
Slack
Sep 5, 2015 06:42 PM
Rupanrx
Sep 4, 2015 06:44 AM
