What would you do?
Old Nov 2, 2009 | 10:30 AM
Kelli_Kitten's Avatar
Unhappy What would you do?
Sooo, unfortunately yesterday morning my blood sugar was really low, I ended up hitting a curb going 25mph- a small curb, 2/3 to half the size of a normal one - and bent both rims... flattening both tires on the passenger side.
Towed it to the place I usually take my car to - in my old car this happened and they usually fixed it for free, I was going 80mph and hit a curb - and today they call and tell me;
1.) My alignment has been off leading to inproper wear on my rear tires (they just inspected/did oil change, why was this not brought up then?).
2.) I destroyed my rear TMPS on my right rear wheel.
3.) Probably further knocked out my alignment.
4.) Front wheel is cracked, back I will need to replace too.
5.) 3 new tires (both rear and front right).
So, for;
a.) 125 a wheel I can get them fixed, $250, 4 new tires will be $600, installation + alignment = over a grand
b.) at tirerack.com I can get all new OM wheels, tires with new TMPS mounted and shipped for less then a grand.
c.) trust eBay and order 2 mazda rx8 rims $350
d.) go for a second opinion at another shop? This shop has been GREAT to me and my family for yeaarss... but lately they have been pulling this?
I appreciate all opinions/thoughts/comments .
Last edited by Kelli_Kitten; Nov 2, 2009 at 10:34 AM. Reason: correction of dollar amount
Old Nov 2, 2009 | 10:35 AM
dozer's Avatar
on his 3rd rx8
try lookin for rims in the for sale section
Old Nov 2, 2009 | 10:37 AM
kersh4w's Avatar
Hit & Run Magnet
get new tires+rims.
on my old car (with crappy $90/tire all seasons) i would never notice when i would replace just ONE tire.
i had my rear driver tire slashed, and i replaced both rear tires. thankfully the geico adjuster gave me the money for a "detail" which almost covered the 2nd rear tire.
it is not the same around turns. the back tires, being newer, have quite a bit more grip, the car will understeer and it will kick on DSC/TC and really ruin a lot of driving fun. also, it makes it kind of scary when the car wont go around a turn properly.
i will always go 4 new tires now.
its winter now, you could pick up a set of winter tires for $550-800. comes with rims. already mounted and balanced. usually 17s. search the forums, i believe several winter packages are not sold, even though they maybe 6+ pages back.
then, when spring rolls around, have the tires demounted and slap some normal tires on there.
you could even sell the winter tires.
Old Nov 2, 2009 | 10:46 AM
Originally Posted by kersh4w
get new tires+rims.
Awesome, I'll look around! Thank you!
Old Nov 2, 2009 | 12:03 PM
alnielsen's Avatar
Go to the shop and have them show you the wear pattern on the rear tires. It is possible that there is abnormal wear on the inside of the tire and you do need an alignment. Your car is at least 4 yrs old now and a all wheel alignment wouldn't be a bad idea.
Old Nov 2, 2009 | 12:12 PM
mscamp02's Avatar
Blue Bullet?
shouldnt cost you 125 to get fixed....I hit a huge drain at about 20 mph's and bent the rim bad and had a local welder fix it for 45 dollars and havent had a problem out of it since
Old Nov 2, 2009 | 12:16 PM
rodjonathan's Avatar
silent assasin
you could just get a new set of rims and tires i know there have been quite a few in the fs section lately you will have to dig em out though ill try and see if i can find some and bump them for you ...
Old Nov 2, 2009 | 12:26 PM
Brettus's Avatar
Boosted Kiwi
great excuse to upgrade to some new rims that will make your ride look even more awesomer
Old Nov 2, 2009 | 01:05 PM
Right now I'm weighing getting all new rims and tires or getting two new mazda rims and 4 new tires... definitely an alignment!
Old Nov 2, 2009 | 11:22 PM
fyrstormer's Avatar
2009 RX-8 Touring
I didn't think you could repair alloy rims?
Old Nov 3, 2009 | 01:53 AM
nvrfalter's Avatar
tonybob failpants
i think this is a good time to go aftermarket wheels. you could probably find a buyer for the 2 oem wheels that are still good.
Old Nov 3, 2009 | 11:18 AM
Pendleton's Avatar
Roto-rookie
And keep a couple snickers bars in the car. I have slight hypoglycemia and if I don't eat every 3 or 4 hours I feel like keeling right over.
Old Nov 4, 2009 | 04:44 PM
04RX8man's Avatar
Rotary Powered Countryboy
AFTERMARKET wheels...
Old Nov 4, 2009 | 04:48 PM
dshiznit1489's Avatar
Formerly Polak Graphics
Buy my rims.
Old Nov 4, 2009 | 05:21 PM
AJ's Shinka's Avatar
Enthusiast
Aww...I'm glad you didn't get hurt. I would think about getting some new rims if you could afford it. I'm sure if you took it to another shop they would competively mark down the prices that the other shop quoted you.
