Clutch feels weird
Old Oct 30, 2009 | 09:25 PM
Twiztog43's Avatar
CA Clutch feels weird
i was wondering if this is the normal feeling of the clutch because my clutch bracket broke a few weeks ago and i had the dealer weld it back together last week.
so right now im not sure if it is the car or just me being paranoid, but when ever i press the clutch, it is kind of soft for a couple cm and then gets a bit heavy [stiff]
is that normal?
Old Oct 30, 2009 | 09:34 PM
souljamcdiddy's Avatar
mine's easy peasy all the way to the floor... have had the slight squeaking noise for about 2yrs. Hasn't broke yet. Although I won't be suprised when it does after reading about the pedal snappage.
Doesn't feel normal - take it back?
Old Oct 31, 2009 | 01:05 AM
deadphoenix52's Avatar
meh.
you're fine
Old Oct 31, 2009 | 02:08 AM
Twiztog43's Avatar
yeah, maybe im just being paranoid. ever since my clutch snapped on the freeway going 70 ive been kinda iffy about my clutch.
Old Oct 31, 2009 | 02:38 AM
chris__n's Avatar
my car is brand new and has a bit of play at the top. you can adjust the pedal if that annoys you.
Old Oct 31, 2009 | 08:43 AM
mscamp02's Avatar
Blue Bullet?
most will have that bit of play before your clutch will actually engage
Old Oct 31, 2009 | 09:09 AM
04RX8man's Avatar
Rotary Powered Countryboy
prob just normal freeplay....you should b fine
Old Nov 1, 2009 | 05:55 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
My pedal looks okay, too bad the clutch itself decided to die after 36K of not that hard of driving on my 05....
Old Nov 2, 2009 | 01:59 AM
Twiztog43's Avatar
CA
The clutch pedal free-play is supposed to be set at .26"-.59" (6.6mm-14.9mm) at the pedal pad (the part you press with your foot). When you are actually driving the car it feels like nearly-zero free-play.
Is this what you have?
yea, thats basically what is going on.
i wasnt sure if that was normal because ever since ive had the car [since april 09"] it was never like that... even when it started squeaking around the end of july and then finally the clutch bracket finally gave way 3 weeks ago! now its basically what you described, a bit of play when i press it for a bit but then it gets a bit stiff from there on until its pressed up against the firewall.
i just wanted to be sure if that was normal because i dont know what a normal clutch feels like on an rx8 since mine was most likely already giving way since the very first day i brought it home.
Old Nov 11, 2009 | 12:38 AM
Twiztog43's Avatar
ok... so i plan on getting the Race Roots clutch pedal support bracket maybe next week but i was wondering if this looks normal...
if you look at the clutch pedal compared to the brake pedal it looks kind of off. i had the clutch assembly welded back by Galpin Mazda (405 & Roscoe) when my pedal snapped.
RevMeHarder
Jun 1, 2026 02:30 PM
Chapsy
Sep 22, 2015 09:57 AM
Frosty8
Sep 11, 2015 10:27 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
