anyone with the 09 oil pressure reading
Old Oct 27, 2009 | 11:38 AM
olddragger's Avatar
as the title says--lots of discussion going on about engine oil pressures. The 09 lubrication system had some major changes to it. I have not seen anyone speak or reveal the 09 engines oil pressure.
Help?
Olddragger
Old Oct 27, 2009 | 11:53 AM
EMart11b's Avatar
Bang Bang
Wink
https://www.rx8club.com/series-i-tech-garage-22/renesis-oil-pressure-discussion-dealer-tech-183519/
Search noob
You posted in that thread... I'm lost.
Old Oct 27, 2009 | 12:14 PM
I think OD is talking about "REAL LIFE" oil pressure readings. not on-paper spec.
Old Oct 27, 2009 | 12:22 PM
EMart11b's Avatar
Bang Bang
Yea, probably.
I don't think anyone has been able to get any oil gauges hooked up in an 09 because of the new oil filter location and it's not part of the OBDII bus.
Old Oct 27, 2009 | 09:00 PM
olddragger's Avatar
That is what I have hoped to be wrong SOMEWHERE
Surely someone has a reading?
What does the factory manual say is spec pressure?--we have the by pass pressures's but i am looking for the engine running pressure min-max.
OD
Old Oct 27, 2009 | 10:13 PM
TZ250's Avatar
I called RB about a gauge set for my '09 the other day. They said no one there had done anything yet for '09 gauges, at least as far as the CS guy knew. I would not be surprised with the totally anemic sales figures if aftermarket parts were very slow in coming. especially ones with any serious development cost. I don't recall exactly. but I think annual units moved 09/30/08 to 09/30/09 was 3,300. Please correct me if I'm wrong.
But there are vendors on the forum who have a lot more insight than me about this. Maybe they can pipe up and let us know what's coming.
Old Oct 28, 2009 | 08:52 AM
olddragger's Avatar
thanks for the info dude. Does look dismal doesnt it.
I cant believe that no one in the world has real time data of the 09's oil pressure. Jeez.
OD
Old Oct 28, 2009 | 09:30 AM
I am pretty sure the sandwich plate works for 09+ too. the oil filter based is the same size.
Any 09 around NYC ? I can just take mine off and put it on to get the readings ?
Old Oct 28, 2009 | 10:37 AM
EMart11b's Avatar
Bang Bang
It doesn't work because of the shield they put around the filter from what I've heard.
Old Oct 28, 2009 | 11:25 AM
hmm ... really.
oh well
Old Oct 28, 2009 | 11:33 AM
yeah, I've also heard the sandwich plate won't fit in the '09 so it could be some time before we have real-time oil PSI readings from an '09 owner.
Old Oct 28, 2009 | 11:41 AM
EMart11b's Avatar
Bang Bang
I wonder if you can't just remove the shield altogether. I haven't read anything about it's function besides making it impossible to use the sandwich plate and preventing the use of non OEM filters.
Old Oct 28, 2009 | 12:45 PM
RenKat's Avatar
Sending Unit
Tee off the oil pressure switch.
Old Oct 29, 2009 | 02:47 AM
ayrton012's Avatar
Ayrton Senna Forever
Somebody just would has to check it in a service shop with a general pressure tester gauge connected to the hole of the oil pres. switch.
Old Oct 29, 2009 | 08:55 AM
olddragger's Avatar
i wish somebody would and get per 1K readings. This may become a very important thing to know.
OD
Old Oct 30, 2009 | 01:35 AM
ASH8's Avatar
Super Moderator
OD
Is this what you are after OD, I have only posted it about 10,000,000,000 times...
but what do I know...
That is all the factory specs I can find at the mo on running pressures, even checked the Factory WS Manual, half useless, all they are today (manuals) are resistance checkers (electrical) if it fails meter test you throw part out.
Old Oct 30, 2009 | 01:39 AM
ASH8's Avatar
Super Moderator
Not so easy, the 09 does not have the Oil Pressure Switch by or under the Oil Filter like S1's, it is located on top of the motor RH Side under air intake gear, and it is attached to ONE of the EMOP's and is larger and different also wiring wise..
I have also posted this 120,001,256,001 times.
Old Oct 30, 2009 | 01:45 AM
ASH8's Avatar
Super Moderator
Please read this post (and thread) it may just answer some of your enquires...(as I duck for the flames!!)
https://www.rx8club.com/showpost.php...62&postcount=1
Old Oct 30, 2009 | 09:11 AM
olddragger's Avatar
Ash--mate---I think i have read it 10,000, 000, 000 times!Lol
No what I am looking for is how the 09's pressure is building---per 1K. What is the actuall pressure at idle, at 3K and so forth .
You started this and I am dang glad you did.
OD
Old Oct 30, 2009 | 10:00 PM
ASH8's Avatar
Super Moderator
Here OD...
This is the 09 Oil RETURN pipe, it bolts (2) in the same position as the S1's where the Oil Filter Housing used to go...
But see the Hexagonal or "Allen Key" GRUB Screw, I am thinking perhaps an Oil Pressure Guage fitting could be tee-ed off from this screw??, it is quite easy to access, anywhere else is a nightmare of removal...
What do you think...??
Old Oct 30, 2009 | 10:41 PM
TZ250's Avatar
I just changed my oil filter for the first time and it sits up inside a cast in shroud so:
http://i732.photobucket.com/albums/w...erlocation.jpg
There in no way to get rid of that.
Old Oct 30, 2009 | 10:44 PM
I never seen a 09 engine bay in person so im not so sure but ...
from your picture, it seems that there is 2 bolts holding down the shroud ? maybe we can remove that without any harm ?
Old Oct 30, 2009 | 11:02 PM
TZ250's Avatar
The filter isangled slightly down and to the rear for clearance. The filter seat is machined into the base of the same shrouded assembly as far as I could tell. It's full shrouded on 3 sides. I've never installed a filter base for OP sender but I assume they are somewhat larger than the filter and would not likely fit. Filter is a close fit as you can see. Cap wrench is the only way to get it out. Must be an easier way to pull OP reading as some suggested earlier.
I nicked the photo from the DIY thread on '09 oil change.
Old Oct 31, 2009 | 03:01 AM
ASH8's Avatar
Super Moderator
Great to get to isn't it...Not..
I have changed about 5 filters and it is never "easy" like earlier RX's, but I guess it is progress as now all the oil is filtered before it goes through coolers, EMOP's and engine..
You still can't help making a bit of an oil mess..
And yes, almost impossibly to remove the cast alloy flange, I think it serves two purposes as a guard or protector and to prevent owners from installing larger filters?
Here is another angle of the 09 filter set up...and that round thing on top (like a flash light battery) is the OCV Oil Control Valve.
Old Oct 31, 2009 | 07:51 AM
TZ250's Avatar
Nice job. I thought about it, but decided not to take the motor out to change the filter, though it might have been easier.
It is in a nasty place. And if you jack it on the left to get to the filter, you can't get all the oil out due to the forward left corner placement of the drain plug in the pan.
I think I need a lift in the garage.
