Engine feedback through speakers when charging iphone
Old Oct 27, 2009 | 07:59 AM
joebennz's Avatar
the swirlinator
i posted in the tech section but didnt get any help so ill try it here
I recently have done the ipod integration where you splice the iphone wire to the cd player and play a silent cd. when the audio wire is plugged in, it sounds crystal clear.
however, when I plug in the charger and the audio wire, i get terrible engine noise coming through the speakers, even when i have the radio on fm instead of CD.
does anyone know what is causing this and/or how to resolve this issue?
thanks in advance
Old Oct 27, 2009 | 09:37 AM
mbentley's Avatar
zoom-zoom
three words: ground loop isolator
Old Oct 27, 2009 | 09:46 AM
Huey52's Avatar
Registered Zoom Zoomer
Yep. Your iPhone charging loop is poorly grounded/shielded and thereby conveying the RF transients to the audio system (high voltage ignition spark is the usual RF noise culprit).
Ground loop isolate the circuit [ultimately best to the battery negative terminal]. http://www.radioshack.com/product/in...ductId=2062214
Old Oct 27, 2009 | 09:58 AM
joebennz's Avatar
the swirlinator
wow you two should check out the tech forum more often lol. thanks for the solution
another question though; i dont have any rca inputs to connect that to. i have a 3.5 mm to rca wire that i cut to solder to the cd player pins in the back of the stock radio.
so what would i have to do to make this work with this setup?
again thanks for the prompt responses
Old Oct 27, 2009 | 09:59 AM
mbentley's Avatar
zoom-zoom
they make ground loop isolators that work with 3.5 mm plugs.
Old Oct 27, 2009 | 10:04 AM
joebennz's Avatar
the swirlinator
lol simple enough. pardon my ignorance and thanks again for your help
Old Oct 27, 2009 | 10:37 AM
Pico's Avatar
It's Complicated
Yep
Isolate the ground and all will be fine.
Common problem with a simple fix
Old Oct 28, 2009 | 08:40 AM
joebennz's Avatar
the swirlinator
went to radioshack and bought myself a ground loop isolators and a few adapters and viola, no more noise. thanks everyone :thumbsup:
Old Oct 28, 2009 | 08:41 AM
mbentley's Avatar
zoom-zoom
good deal glad to be of assistance
vapor2
Nov 3, 2020 03:38 PM
BigKid
Sep 23, 2015 07:46 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
Majictoast
Jul 18, 2015 06:45 PM
