CEL code 2109 and 2112
Old Oct 25, 2009 | 09:51 PM
Rote8's Avatar
No, it's not a Rush song.
I got a surprise, no throttle action!
Car cranked fine, idled high, but throttle no workey....
CEL scan shows 2109 and 2112.
P2109 TP sensor minimum stop range/performance problem ON 1 CCM ´
(See DTC P2109 )
P2112 Throttle actuator control system range/performance problem ON 1
CCM ´ (See DTC P2112 )
It was crud in the bottom of the throttle body tube, blocking the throttle plate from moving correctly.
WD-40 and a rag to clean it and the throttle works fine.
Old Feb 28, 2017 | 02:50 PM
1Sontov's Avatar
did the code zero itself out and the check engine light now OFF? (P2112) I have same issue... after cleaning it, should I disconnect the battery to cancel out the codes?
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
