Handbrake acting up??
Old Oct 25, 2009 | 04:49 PM
skhmund's Avatar
THE BITCH IS DEAD
Hi i have 05' 6spd mt and I just took her to the gas station to fill her up and when I pulled out of the driveway of my house onto the road and started shifting, I noticed the handbrake light would come on and off even tho the handbrake was down. It would come and go I noticed. At the stoplight, I pulled the handbrake up and down to make sure it was down properly. But the light still came and went. I do know that I have not driven the car for over a week because I was out of town....
Any thoughts??
Old Oct 25, 2009 | 05:13 PM
Jon316G's Avatar
Grasshopper
I would first inspect the e-brake switch for anything unusual (no comments needed on my dirty center console ):
Old Oct 25, 2009 | 05:15 PM
expo1's Avatar
He's as bad as Can
+1 See attached file
Old Oct 25, 2009 | 05:22 PM
skhmund's Avatar
THE BITCH IS DEAD
Thanx, ill go try the inspection out! Curious but do we do this with car on or off??
And also, I was at the stoplight and I slammed the gas in first and right before i was about to hit redline, i saw the handbrake light come on and then go off.
Old Oct 25, 2009 | 05:26 PM
Jon316G's Avatar
Grasshopper
Have you checked the fluid level?
Old Oct 25, 2009 | 05:33 PM
skhmund's Avatar
THE BITCH IS DEAD
Ok I just did the inspection and if I'm hearing the right "clicks," then I should be good.
And no, I forgot about the fluid lol I actually never checked that before so where would it be exactly??
I think I'll take her for a test run in a bit to see if the problem still exists
Old Oct 25, 2009 | 05:44 PM
Jon316G's Avatar
Grasshopper
Better start RTFM buddy
Old Oct 25, 2009 | 05:49 PM
Jon316G's Avatar
Grasshopper
And one way to find out if the e-brake switch is the culprit or not is to remove it from the equation.
Way to do this is simply disconnect the wire harness to the switch and take a single piece of wire and jump it between the two terminals (on the wire harness, not the switch).
The switch is N/O (normally open) so by jumping the wire, the PCM will think the e-brake handle is always down even if its not.
If the brake light doesn't return, then you know where to focus your attention.
Old Oct 25, 2009 | 06:05 PM
skhmund's Avatar
THE BITCH IS DEAD
TX
Alot to take in, but thank you for the info, well appreciated. I just came back from driving her. I redlined her a couple times, no light, drove her like normal n still no light. I am no mechanic or auto junkie, but I can only conclude that it was a result of me not driving her for over a week. She just sat in the garage while I was away. If the problem returns, then I shall know what to do.
btw, driving BAREFOOT is so much fun. I didn't wanna put on sneakers just to go drive her down the hwy n back so i just went barefoot. I noticed I shift alot better barefoot. I wonder if it is illegal to do that here in TX....
Old Oct 25, 2009 | 08:25 PM
laythor's Avatar
I zoom therefore I am.
look at the threads around shoes for driving. going barefoot is NOT the best thing to do.
Old Oct 26, 2009 | 09:17 AM
skhmund's Avatar
THE BITCH IS DEAD
I'm pretty sure you're right about that haha I've noticed if I wear my nike shox that are more narrow n long vs my other sneakers, i shift better.
Old Oct 26, 2009 | 09:32 AM
Huey52's Avatar
Registered Zoom Zoomer
Always good to check the hydraulic fluid level, but the e-brake is a mechanical link, as in when you lose everything else, you still have [non-power assisted] emergency [rear wheel] braking.
OnebaddRx8
Aug 25, 2019 11:34 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Digitz0070
Oct 7, 2015 12:43 PM
GARCIAC951
Sep 10, 2015 07:17 PM
