17 or 18 in wheels
Old Oct 25, 2009 | 02:56 PM
rx8noob's Avatar
17 or 18 in wheels
I am looking for opinions on running a 17x10 +25 wheel as opposed to a 18x9.5 +30 offset. I have a 06 whitewater pearl 8 bone stock with minor diy appearance mods. I will be running tein s tech springs so i was wondering if anyone had any advice on running the 17 over the 18. I will be running a fat tire on this setup probably the rt615s. Any rubbing on this setup and is it a mistake to switch down to the 17 from the stock 18s?
Old Oct 25, 2009 | 03:12 PM
IMHO even with the stechs, your car will still look like a 4x4. If I were you I'd stick with the 18's as anything smaller always just looks wierd. the 17's might be a tad lighter, depending on what wheels you choose obviously. And no, no mistake switching from 18 to 17.
Old Oct 25, 2009 | 04:09 PM
TopGear8's Avatar
mkuhnracing.com
Yes you will rub on either set up.
Old Oct 25, 2009 | 08:18 PM
kersh4w's Avatar
Hit & Run Magnet
im switching to 17s when (eventually) get rims.
Old Nov 3, 2009 | 01:19 AM
rx8phase1's Avatar
If you get 17's check out some enkei rpf1's and stick some wide tires on them and lower ur car trust me they look sick!
Old Nov 3, 2009 | 01:27 AM
thebiggdaddy's Avatar
The only way the 17's would look good is if the car was slammed. Since you don't have coilovers, I would go with the 18's. Also, posting some pictures of the wheels that you were interested in would help. Some designs look better in 17's than 18's.
Old Nov 3, 2009 | 08:43 AM
gh8st's Avatar
STiMPACK
i'm going with 17s next as well.. either work emotion 11r 17x9.5 or 5zigen fno1r-c 17x9.5
Old Nov 3, 2009 | 02:28 PM
c0ldf1ame's Avatar
my friends got the 5zigen fno1rc in 17x10s last i saw he was on stock suspension though, that thing should look good once its lowered a bit, the only thing that comes to mind for me is that if you ever want to upgrade your front brakes, you'd have to switch back to 18s, its lighter and tires will probably be cheaper
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
