Leading or trailing plug difference
Old Oct 24, 2009 | 03:03 PM
Sprout's Avatar
Sprout
Hello - Can anyone tell me the difference between the leading and trailing plugs? And - how often do they tend to go bad? Thanks! Sprout
Old Oct 26, 2009 | 12:35 AM
Wren's Avatar
Gidday, Dont get them mixed up .The Trailling plug has a hotter spark than the Lead one.If you look on the block beside the plugs you will see it marked "T" or
"L" to identify them, also the lead spark plug is longer than the trailling plug so dont put the wrong sort in ,otherwize 'CRUNCH'
Old Oct 27, 2009 | 10:34 AM
Mazmart's Avatar
Their failure can be caused by different things. Generally over time they can lose effectiveness as they wear but they are irridium which is one of the ultimate materials used in the ignition game. The environment in which they live can be very tough, especially in a rotary engine where they are firing very frequently. As Wren pointed out, they are a different heat range to each other; however the trail are colder than the leads, not the other way round.
Paul.
Old Mar 30, 2022 | 03:42 PM
Redbeardmack's Avatar
What do you mean "crunch" I just bought one and they had the plugs reversed and pull the plugs out and see no sign of contact
Old Apr 14, 2022 | 10:37 PM
consider the source i.e either fake or not-informed news bro’ …
Old Aug 14, 2022 | 10:26 AM
Loki's Avatar
It might have fouled more than normal, but I don't think it would do lasting damage. There could be secondary problems like poorer fuel economy and more load on the cat over long term, so depends how long it was like that. But we're not talking huge differences.
ASH8
9
Jun 7, 2024 09:52 PM
John Kim
Mar 18, 2019 02:16 PM
KrylonFuzion
Feb 21, 2008 01:56 PM
v300
45
Feb 3, 2005 10:08 PM
Dookie_Rx-8
23
Jan 18, 2005 06:08 AM
