Power cuts off around 6500 rpm (no cel)
Old Oct 22, 2009 | 06:17 PM
Shijin-Kun's Avatar
Rotary Power!
So ive been doing some research since i dyno'd my car. Here are the results.
The point were it start to dip is 6500rpm and thats were the APV should open to give the engine more air. My question to the community is there a way to check the APV motor? myself or should i just take it to the dealer and have them replace the whole thing. I have a 2004 currently sitting on 80k miles. Also ill mention that when i redline it i dont get a cel ( i do redline the car every time i drive it, not sure if the owner before me did). Any suggestion, thoughts, comments?
Old Oct 22, 2009 | 06:23 PM
Jon316G's Avatar
Grasshopper
This shows how to test the APV motor.
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-troubleshoot-intake-valves-174009/
Not sure the APV stuck closed will give you that kind of result, but lets see what others have to say about it.
Old Oct 22, 2009 | 06:35 PM
Jon316G's Avatar
Grasshopper
BTW... my video doesn't really show you where to connect the power source, so here are a couple pics to help:
Power cuts off around 6500 rpm (no cel)-apv.jpg Power cuts off around 6500 rpm (no cel)-apv2.jpg
Old Oct 22, 2009 | 08:06 PM
Shijin-Kun's Avatar
Rotary Power!
Thanks Jon thats very helpful....now if i only knew how to take off the intake manifold lol
Old Oct 22, 2009 | 08:08 PM
Jon316G's Avatar
Grasshopper
LOL... see if you can reach the APV motor through the passenger-side wheel well
Old Oct 22, 2009 | 08:11 PM
Shijin-Kun's Avatar
Rotary Power!
I can just remove from there? cool i give that a try this weekend. Any other suggestion on what it could be guys?
Old Oct 25, 2009 | 08:13 PM
kersh4w's Avatar
Hit & Run Magnet
the good news is that you were making 175whp at 6500rpm.
thats good!
people that dyno 165whp around there and go on to make 190-200whp.
Old Nov 16, 2009 | 03:20 PM
Shijin-Kun's Avatar
Rotary Power!
update i tried to remove the APV motor from the intake from the right tire well but could not remove one of the bolts because there were 2 pipes in the way. So i just disconnected the APV and applied the 12V DC adapter and i heard the motor turn. I connected the APV back and i had my gf put the car in the on position for a couple of seconds then turned it off and i heard the car testing the APV motor from the right tire well. I drove the car up to 9k rpm and i noticed that the engine sounded louder and did struggle to reach 6.5k to 9k rpm. Next weekend we have a Dyno day coming so we will see if the issue was resolved. Jon thanks for the help.
Old Sep 18, 2011 | 01:58 AM
KidZoom's Avatar
Dammit Jim, I'm a doctor.
What was the resolve of this matter?
Old Nov 7, 2011 | 05:00 AM
ikilldinosorurs's Avatar
ikilldino
yea im kinda haveing the same problem it wont move past 6500 rpms and gets way lowder when i push it. no codes or light *** up. hope you get the anser.
Old Nov 7, 2011 | 06:12 AM
bse50's Avatar
#50
search, it may easily be an intake valve being stuck.
Which one is up to you to search.
Old Nov 11, 2011 | 12:17 AM
or you may want to search "clogged cat*"
cushing75
Nov 12, 2018 12:46 PM
uZu
Dec 30, 2015 12:35 PM
Solmors
Aug 21, 2015 10:11 PM
atmd
Aug 19, 2015 12:43 PM
Rx808BI
Aug 9, 2015 10:06 AM
