Redline... and then what?
Old Oct 21, 2009 | 08:08 PM
shallowater's Avatar
I redline in 2nd gear, but am a little bit confused about what to do next...sometimes i just shift from 2nd to 6th gear directly since the car is already going at 60mph+, sometimes i shift from 2nd to 3rd to 4th etc...
what is the preferred way to do it (a.k.a, better for engine/trany)?
also, i remember seeing someone saying that one should redline by flooring gas to burn off the carbon, holding gas pedal half-way down till redline is not going to help much in burning carbon residue...is that true?
Old Oct 21, 2009 | 08:10 PM
mscamp02's Avatar
Blue Bullet?
honestly....it really doesnt matter what you shift to. And if your going to redline it you might as well enjoy it and have the pedal all the way down
Old Oct 21, 2009 | 08:23 PM
RIWWP's Avatar
WOT = Wide Open Throttle. You are really only going to the max burn by pedal the whole way down. The higher the load, the better the burn, the better the carbon cleaning. Half way down on the pedal is only part load, so only part of the cleaning power.
What you do next is up to you, your driving style, and the conditions around you.
Old Oct 21, 2009 | 08:30 PM
it is certainly a driving style thing...i am just wondering if the engine/tranny will take it differently
Old Oct 21, 2009 | 08:31 PM
myriadshalaks's Avatar
rot8ing
i usually pull the e-brake at that point. try that.
Old Oct 21, 2009 | 08:33 PM
I8U's Avatar
I8U
The only thing the tranny doesn't like is if you decide to run it constantly at high rpms...7500+. I have seen plenty of trannys give up then, coming from a racing standpoint. Anything less and you should be good.
Old Oct 21, 2009 | 08:37 PM
SayNoToPistons's Avatar
Wheels, not rims!!
I like to jamb it into reverse.
Old Oct 21, 2009 | 08:39 PM
Bullitt's Avatar
In the pipe five by five.
Yeah, that's fun, but the sound kinda grates on me.
RyansRx8's Avatar
Brettward is/has a G
redline then boner
Old Oct 21, 2009 | 09:52 PM
JinDesu's Avatar
went back to srsly broke
Hah, you're punny. Unless you didn't mean to be, then it's funnier.
Old Oct 21, 2009 | 10:07 PM
kersh4w's Avatar
Hit & Run Magnet
i try to pull a 180 without leaving my lane.
keeping the throttle all the way down.
Old Oct 21, 2009 | 10:38 PM
MazdaManiac's Avatar
I just leave it in 2nd and keep the pedal down. Keeps me from speeding. Sorta.
Old Oct 22, 2009 | 01:16 AM
rubberduckie's Avatar
Shift and redline again?
Old Oct 22, 2009 | 03:20 AM
NautyOne's Avatar
Touge Addiction
I throw it in neutral.
Old Oct 22, 2009 | 06:37 AM
then?
3rd gear or 6th?
Old Oct 22, 2009 | 07:02 AM
Bigbacon's Avatar
2006 WB AT
If you redline for 2 minutes then throw on a Journey song with the volume at 10, you'll go to plaid!!!
Old Oct 22, 2009 | 08:18 AM
JinDesu's Avatar
I tried this on a local street. It definitely didn't keep me from speeding. Damn you for faulty advice.
Old Oct 22, 2009 | 09:25 AM
dillsrotary's Avatar
jersey fresh
Originally Posted by shallowater
then?
3rd gear or 6th?
you are putting WAY to much thought into this...
This is what i do, if i have a passenger after i redline 2nd i punch them in the face and yell, "did you feel that?!"
Old Oct 22, 2009 | 09:31 AM
adamwzl's Avatar
<3's Bunnies
after redlinng 2nd i put it into 5th then once I redline 5th I put it into 3rd. Red line that and then drop it into 6th. If I want to go faster I put it in R for "Race Mode"
Old Oct 22, 2009 | 09:43 AM
hakuna matata!
freaking redline 2nd into 3rd and redline that.. then call it a day... or multiple times a day
like dills said, you are thinking way to much into this... think about what you are trying to do in the first place.. don't redline because we're telling you too.
jersey fresh
or even better, if a toddler is in the car punch the toddler.
Old Oct 22, 2009 | 10:00 AM
CTrx8's Avatar
space for rent
or a cat - cat's are fun and easy to punch. but then you have to think to yourself, "how the hell did a cat get into my passenger's seat and put on its seatbelt? and why is it wearing a tuxedo?"
oh, i hope pink flea doesn't see this.
Old Oct 22, 2009 | 10:14 AM
i don't get these random comments...you guys can have as much fun as you want in this thread, i don't really care. but i just hope someone can tell from a pure mechanical point of view: will redline in 2nd and shift to 6th directly harm the engine/tranny (since u r skipping 3 gears)?
Old Oct 22, 2009 | 10:39 AM
CyberPitz's Avatar
Huge hole is huge
No, absolutely no damage will come from skipping gears, as long as you don't try to shift from 9k RPM straight to 6th really fast. Most cases, you'll get a quick grind. Redline in 2nd, neutral, then slowly shift to 6th and call it good.
On note of the fun:
Usually whenever I redline in 2nd, I activate my boosters and hit my "ramp" button, then fly to the moon to say Hi to the Mooninites.
Old Oct 22, 2009 | 10:42 AM
dozer's Avatar
on his 3rd rx8
i no longer shift at redline, i shift in the REDZONE
