SE RX-8 Forum Serving NC, SC, GA, FL, AL, TN
Baro pressure sensor vacuum line
Old Oct 20, 2009 | 04:09 PM
shastamaxine's Avatar
Hi to all rx8 owners
I just bought a rx 8 2005 automatic transmission.car is just fine.I notice the baro pressure sensor vacuum line is missing,it has been cut.I am about to connect a new vacuum hose,but i can't find where on the engine it must be attach.If anybody knows where it must go,please give a hand.
thanks
Old Oct 20, 2009 | 05:44 PM
czar's Avatar
Almost boosted
it doesnt, it just sits there so it can measure the atmospheric pressure during start up
Old Oct 20, 2009 | 05:57 PM
MazdaManiac's Avatar
+1
Its not supposed to be connected to anything.
Old Oct 21, 2009 | 06:19 AM
ok, thanks for your reply.It's gives me peace of mind regarding this.
thnaks
Old Sep 20, 2017 | 04:53 PM
Stickiertuna's Avatar
Bypass
How do i bypass this garbage sensor. It went bad and i have diagnosed after changing all other options. I gain lots of power after disconnection. But i throw codes. Just wanna bypass as i don't drive in any other altitudes. I'm not paying 140+ for a sensor i don't need.
Old Sep 20, 2017 | 04:59 PM
StealthTL's Avatar
Metatron
Haven't heard of a (successful) bypass.
Suck it up Princess, you found the problem, now buy the sensor that you need.
Old Sep 20, 2017 | 05:09 PM
Screw that sensor. After a turbo upgrade it's obsolete. "Turbo coming first of year as funds allow." I will not buy a over priced sensor just to remove it in a couple months. Someone has to know how to get rid of this problem.
Old Sep 21, 2017 | 02:45 AM
Maybe if you stop acting like an angry kid throwing a tantrum you'll think it through more clearly. Or not; your choice.
The ECU is looking for a specific output signal from the sensor. All you have to do is input the correct output signal in place of the sensor you consider to be so fubar. However, the sensor output signal varies based on atmospheric pressure. So unless you duplicate that accordingly then the ECU won't be receiving the correct signal to adjust the fuel injectors and timing to the proper settings. More than likely you don't have those parameters tuned properly to begin with and disconnecting the sensor is compensating for this. Then again, maybe you're a genius and the rest of us are lost. God help us all then ....
Old Jun 27, 2023 | 01:14 PM
tytyrx8's Avatar
Will an rx8 not start with a baro sensor with a bad wire?
Read up
WranglerFan
Aug 21, 2022 01:29 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Irvinb16
Sep 11, 2015 10:27 PM
