camthman
10-19-2009, 02:28 PM
So long story short, I took my coilovers off last week and put the stock suspension back on. (including the stock wheels) I get back in the car to take off and the ABS light is on, the the traction control light as well. The never go off. There is a also a loud beep every once in awhile. WTF? I reset the battery and same thing. Any ideas??
-- Cameron
Charlee
10-19-2009, 03:45 PM
Did you go over everything and make sure everything was connected? I believe the traction control sensors could have easily been disconnected with the work that you did.
camthman
10-19-2009, 03:47 PM
Yeah, I did. I mean I never unplugged anything. I also had the guy check it out on the alignment rack.
Mazurfer
10-19-2009, 03:59 PM
Turn the key to on, but do not start. Turn the wheel all the way to the right and then all the way to the left and then turn the key off.
Then start as normal and remember to not shut it off cold!
Would've thought driving around would've done this reset by itself, but it's worth a try.
camthman
10-19-2009, 04:23 PM
I will try this thanks!
