View Full Version : Did something fall off my rx8? :)
buswellj
10-14-2009, 01:30 PM
I think I may have lost a plastic panel or something off the underneath of my rx8. I just had it serviced about a week ago, and while I was driving at night the other day, I felt the rear tire go over something that sounded "plastic", I figured I had ran over a tire fragment or something, but when I looked under the rx8, I saw this blue wire that I don't recall seeing before! :hahano:
Next to where the blue (looks like a grounding wire) is located, is what looks like a hole for a rivot, so I am wondering if I lost a plastic panel or something. Dealership is a good 1.5 hours away so if anyone with an '07 RX8 can take a quick look under their car and see if there is something covering that wire or a plastic panel around there I would appreciate it.
Attached a photo, you can see the wire in the center of the photo.
buswellj
10-14-2009, 01:32 PM
The wheel in the photo is the front passenger side wheel. So the photo is shot from the drivers side..
xun4gvn4everx
10-14-2009, 01:35 PM
That is your 02 sensor wire. And it still looks connected. There is no plastic that close to your cat or it would melt
bhop
10-14-2009, 01:46 PM
Yup, looks like your 02 sensor. I don't use mine since I have a midpipe. I have it tied up sort of so it does not hang.
JGR4444
10-14-2009, 04:01 PM
for sure 02 sensor wire... looks connected so your good man
mbentley
10-15-2009, 11:41 AM
as others mentioned, you are fine. as far as i can remember from last time i had my car on a lift, the only major plastic cover is underneath the engine.
