F.S. Ichiba Version ll 20mm Hub centric Spacers
Old Oct 13, 2009 | 05:28 PM
Pico's Avatar
It's Complicated
Brand New never used 20mm (about 8/10 inch) Hub centric spacers (2).
Version II wheel spacers are made from Aluminum/Magnesium alloy
They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs.
They have the hub centric ring included
I was going to install them-- that's why the outsides are painted with high temp Duli-Color black paint. I decided not to install these at the last minute.
Very Good spacer
SOLD!!!
Old Oct 13, 2009 | 05:32 PM
Nice, just ordered some 25MM's. Bump.
Old Oct 13, 2009 | 05:37 PM
Pico's Avatar
It's Complicated
^ I went with 15mm Ichiba all around instead. Very good spacer, the ride feels the same. No issues at all
Old Oct 13, 2009 | 07:20 PM
dondo's Avatar
100% baller (finally!)
would this make my +45 into +25 then? is that the idea?
Old Oct 13, 2009 | 08:01 PM
Pico's Avatar
It's Complicated
^ yes it would.
Old Oct 14, 2009 | 04:37 AM
Pico's Avatar
It's Complicated
morning bump
Old Oct 14, 2009 | 11:05 PM
Pico's Avatar
It's Complicated
Priced reduced.
They gotta go
Old Oct 16, 2009 | 08:19 AM
Pico's Avatar
It's Complicated
Bump to the top.
There must be someone that could use these. There great for eliminating the annoying fender gap with OEM wheels and for BBK clearance issues.
Old Oct 21, 2009 | 08:13 AM
Pico's Avatar
It's Complicated
Bumpin
Reduced again $100 shipped. They retail for 150 - They have never been used.
Great deal
Old Oct 21, 2009 | 10:39 AM
Man I wish these were 25mm. I ordered 25mm H&R's and the bore size is wrong (my dumb *** fault, I got excited because they were so cheap).
Old Oct 21, 2009 | 04:01 PM
Pico's Avatar
It's Complicated
^ that's sux I hope you found that out before you had the wheel off.
Old Oct 21, 2009 | 04:22 PM
Yeah I found out when I compared them to the Enkei ones I bought.
Old Oct 21, 2009 | 04:24 PM
Pico's Avatar
It's Complicated
Good eye man.
Old Oct 21, 2009 | 08:58 PM
gcthree's Avatar
I'm guessing that I will need to shorten the studs on the car to make these work? The studs are longer than 20mm and I don't see the necessary relief on the factory wheel to allow it nest. Does that make sense?
If these bolt straight on and will work with my factory wheel, I'll take them. Have you tried them on your car?
Let me know....
Old Oct 22, 2009 | 06:50 AM
Pico's Avatar
It's Complicated
I have same 15mm spacers on my car without any issues
I am running the OEM wheel and the spacers definitely give a more aggressive stance.
I did have to slightly cut the OE studs, which is common with any spacer set up.
With the 20mm that I'm selling you wouldn't have to cut to much of the OE stud. 20mm will give you a very flush appearance.
These are quality spacers and will hold up 4sure. Let me know if your interested
Old Oct 22, 2009 | 12:12 PM
kersh4w's Avatar
Hit & Run Magnet
you could get hubcentric spacers. unless its too small. and the hub doesnt really truly matter.
Old Oct 22, 2009 | 01:11 PM
TX
Yeah the four I got are hubcentric, the problem was the bore size on the H&R's is 60.1 which is too small. I got such a good deal on the H&R's I was in a rush to buy them and they were the wrong size. So I have a set of Enkei hubcentric spacers that are perfect, just gotta get the other pair.
Old Oct 23, 2009 | 12:06 PM
Pico's Avatar
It's Complicated
TTT
When you get the other pair I'd love to see how they look.
Old Oct 23, 2009 | 01:25 PM
2tone's Avatar
The RX-8 is missed
hey - pm \\ konig \\
Old Oct 23, 2009 | 03:37 PM
Pico's Avatar
It's Complicated
Pm sent
Old Oct 26, 2009 | 08:49 AM
Pico's Avatar
It's Complicated
Monday Bump.
pm me if interested
Old Oct 27, 2009 | 04:05 PM
jaisy207's Avatar
if you will take $80 shipped i will buy them now
Old Oct 28, 2009 | 12:44 PM
Pico's Avatar
It's Complicated
Pm sent
92trbolzr
May 18, 2025 09:04 AM
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
drlubell
Sep 26, 2015 11:58 PM
WingleBeast
Sep 9, 2015 10:10 AM
