View Full Version : Cyberdyne Gauges
laythor
10-12-2009, 12:02 AM
So I finally broke down after reading Jedi's Racing Beat Gauge pod thread, and installed my own set. Here's Jedi's original thread: http://www.rx8club.com/showthread.php?t=133938
I went with the RB gauge pod but picked Cyberdyne gauges after unsuccessfully trying to purchase Nordskog. Apparently they have been bought out and, for the time being, have ceased operations indefinitely.
First, drain your oil. I find having a friend do most of the work while you take pictures and smoke cigarettes is a very great way of doing this:
http://i43.photobucket.com/albums/e364/mdobilas/Gauges/DSCF1415.jpg
Hmmm... is that Royal Purple? Why yes it is. I've run nothing but dino oil since I bought that car, figured I'd give RP a try.
http://i43.photobucket.com/albums/e364/mdobilas/Gauges/DSCF1418.jpg
The oil filter was being a bit of a pain in the ass, but nothing a long screwdriver and lots of fun can't fix.
http://i43.photobucket.com/albums/e364/mdobilas/Gauges/DSCF1413.jpg
The RB water temp adapter as well as the oil plate are things of beauty, the machining is just top notch. Here's a shot of the water temp adapter installed.
http://i43.photobucket.com/albums/e364/mdobilas/Gauges/DSCF1417.jpg
Here's the oil adapter installed. It doesn't show the grounding wire we installed later... yeah, we forgot until after the install was almost complete.
http://i43.photobucket.com/albums/e364/mdobilas/Gauges/DSCF1412.jpg
This is a shot of what I consider the weakest part of the RB gauge pod. It is curved much like our stock ash tray face plate, but gauge are not curved. This leaves us with two issues. Most standard methods of mounting gauges will not work and we'll be left with some gaps on the sides. Black silicone to the rescue!
It no only fills the gaps nicely but it will also hold the gauges firmly in place. If i ever need to replace a gauge a simple trim with an exacto blade will free the gauge.
http://i43.photobucket.com/albums/e364/mdobilas/Gauges/DSCF1424.jpg
The Cyberdyne gauges come with memory recall of HI and LO. It uses a small switch for each gauge. Since we had time and I just wanted to get a feel for the feature we installed it this way. I'm planning on getting different switches and a new blank, so don't mind the less the straight or centered install.
http://i43.photobucket.com/albums/e364/mdobilas/Gauges/DSCF1425.jpg
Almost done, time to turn on the car and make sure everything works
http://i43.photobucket.com/albums/e364/mdobilas/Gauges/DSCF1427.jpg
All buttoned up and looking nice
http://i43.photobucket.com/albums/e364/mdobilas/Gauges/DSCF1431.jpg
Here's a short video of the HI/LO feature of the gauges. Not sure what the red streaks are, maybe aliens in my car or something.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/V-t_9Wy4w60&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/V-t_9Wy4w60&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
http://www.rx8club.com/attachment.php?attachmentid=146722&stc=1&d=1255320258
chino0314
10-12-2009, 12:03 AM
pure sex good right up
9krpmrx8
10-12-2009, 12:05 AM
Looks good.
laythor
10-12-2009, 01:54 AM
thanks
NgoRX8
10-12-2009, 03:40 AM
they look awesome!
CyberPitz
10-12-2009, 11:18 AM
Very very nice!
laythor
10-12-2009, 08:35 PM
I'm really liking them. It's nice not having to scroll through the AP menu to check water temp and then back to afr's. Also seeing the Oil pressure is pretty interesting.. i've been reading all the oil threads and seeing the actual pressure at different RPM's is nice.
8rotor8
10-13-2009, 12:33 PM
Great work.... uhhh.... Zach!
laythor
10-13-2009, 12:38 PM
in all things there needs to be a supervisor.. that was my role here.
tournapart
10-13-2009, 06:28 PM
Spectator...not supervisor
jk, hahaha...
Good times, was a fun install, I know that ACE hardware like the back of my hand now
Still love the ghetto ziptie washer on the coolant bypass
tournapart
10-13-2009, 06:30 PM
yeah but electrical gauges dont have the resolution that mechanical guages offer...
What a crock of shit, yeah, springs and wax thermo pellets with some bubble gum and paper clips versus a printed circuit board...right
tekk220
10-13-2009, 10:07 PM
http://www.nordskogperformance.net/home.php?cat=8
they appear to have the gauges here...
elf
10-13-2009, 10:29 PM
Those look nice! Good job, laythor.
laythor
10-14-2009, 02:39 AM
thanks elf.. i've been wanting these for awhile
Tekk.. nordskog still has their online store running, but if you place an order you'll get an email the next day stating they are indefinitely ceasing operations.
Zach, I'm still baffled by Racing Beat suggesting mechanical gauges are the way to go, not sure if they just got a great deal on them so that's why their premade kit comes with them or what.
tekk220
10-14-2009, 03:30 AM
I would have to agree that mechanical gauges are the way to go. They are more precise and reliable. I still might get these gauges u got.. they look good
tournapart
10-14-2009, 10:45 AM
as far as accuracy and precision goes, its neither here nor there, more has to do with the amount of R and D a company has invested, or "borrowed"
on the comprehension side, whats easier to read while driving? an analog scale and a needle or a straight up number?
Reliability? solid state electrical systems by far outlast mechanical systems, no moving parts, nothing to wear out, nothing to fall out of calibration
I dont mean any offense, I just strongly believe that electrical gauges are the way to go in the 21st century...
NgoRX8
10-14-2009, 01:40 PM
I agree, these days electrical gauges are essentially the way to go.
analog v digital is a different story. the terms gets misused pretty often. electrical gauges can be analog as well, and most are.
Jedi54
10-14-2009, 04:02 PM
Lookin' good Laythor! congrats on getting these installed, they look pretty sharp, especially with your current interiour setup.
laythor
10-14-2009, 11:38 PM
yep.. can never have too much blue!
Jedi54
10-15-2009, 12:27 AM
do they dim when you turn on the headlights?
laythor
10-15-2009, 12:30 AM
yep, the go to about half strength
laythor
11-24-2009, 09:46 PM
update on these gauges.
AVOID THEM LIKE THE PLAUGE. All three gauges have now lost parts of their display. Cannot get a response from the guy who sold them or the company that makes them to utilize their "lifetime warranty"
DO NOT BUY THESE GAUGES!!!!!!
Jedi54
11-24-2009, 10:05 PM
oh crap!
sorry to hear this Laythor, good luck with that 'warranty', hopefully someone will eventually get back to you and resolve this.
mscamp02
11-24-2009, 10:52 PM
oh man sorry to hear that....they looked damn good to
laythor
11-26-2009, 11:47 AM
I'm not holding my breath for anyone to get back to me on this. Think I'll be chalking it up to one of those "life lessons".
On the up side I've decided to replace them with Defi gauges. The local rotary shop, Rotorsport, carries them and the owner is just an all around great guy. I'm planning on having him install them when my replacement BHR midpipe arrives.
http://www.defi-shop.com/product/rg/rg_top.html#movie
alz0rz
11-26-2009, 11:54 AM
Clean. nice.
Jedi54
11-26-2009, 12:39 PM
those defis should be awesome
warwickben
01-29-2011, 12:56 PM
So I followed a link what happen to the gauges ? What went wrong.
Jedi54
01-29-2011, 01:01 PM
post #22.
did you miss it?
warwickben
01-29-2011, 05:44 PM
At first I didn't understand then it clicked my head lol. I got u now. Thanks for the help
laythor
01-29-2011, 08:21 PM
if this thread kept you from buying these cheap gauges then my money wasnt wasted on them. I ended up getting DEFI gauges and really love them.
warwickben
01-30-2011, 10:26 AM
Yeah I wish I could really justify dropping tons of money on extremely nice gauges . But I'm just na so it mite be over kill lol. I play bass guitar and on the site I go to we have a saying " I got gas". Gear acquisition syndrome , you see nice stuff and just want it lol.
