Engine sluggish
Old Oct 11, 2009 | 08:29 PM
1911_singleaction's Avatar
Engine sluggish
Hi guys,
I have a 2006 Rx8, with approximately 14000 miles driven on it.
This past weekend I drove it for the first time on a long distance trip (from LA to Las Vegas).
During the drive (on the way to Vegas), I noticed that the engine started feeling very sluggish - cars would easily pass me by. The car didn't feel this way at the start of the trip. This was about half way (160 miles out of the 260 miles for the entire distance on the way to Las Vegas). I noticed that this also occured right when the elevation was 4000 feet.
Should I get the car checked out?
Thanks/.
Old Oct 11, 2009 | 09:50 PM
Old Rotor's Avatar
Originally Posted by 1911_singleaction
Hi guys,
Thanks/.
Please give us the history on your car. The service it's had and parts replaced. Type of driving it gets(long commutes, short trip), fuel used(reg or prem), ever flooded, mods installed. Have you ever run any engine de-carbon cleaner to improve compression? You might need this to clean up the carbon buildup from a lot of short drives and not much red lines. Just any thing that you can add.
Old Oct 11, 2009 | 09:57 PM
bhop's Avatar
NO A/C :(
^What he said, You def need to redline everyday IMO. Another contributing factor can be your ignition coils/sparkplugs. What exactly do you mean when you say "sluggish" because there are quite a few ways to describe that term?
Old Oct 12, 2009 | 07:26 AM
Pico's Avatar
It's Complicated
"Should you get it checked out"? I hope that's a rhetorical question.
Problems never go away they get worst. As stated above give us a little history on your ride, CELs, Flashes, etc. etc. People here can help narrow the problem down.
In the end you should bring the car to the dealer if it is found to be a major problem
Old Oct 12, 2009 | 09:15 AM
CAT dying or Engine going Kaaaabooooom.
Old Oct 12, 2009 | 09:39 AM
Huey52's Avatar
Registered Zoom Zoomer
^ ... but he's only got 14k miles on it! Then again, he may be related to "I ain't got no good Rex karma" nycgps.
Old Oct 12, 2009 | 10:20 AM
Blackfire's Avatar
iDIY
i had quite a "slugish" rx8 awhile ago it felt like it wouldnt pull either and was bogging a bit, i checked my engine fluids ect... and it was the coils and plugs, after i changed them i got my power back and feels much smoother. so maybe check ur coils and plugs?
Old Oct 12, 2009 | 10:52 AM
CyberPitz's Avatar
Huge hole is huge
He did say he was at 4000 elevation....what elevation are you at normally?
Old Oct 12, 2009 | 11:36 AM
Huey52's Avatar
^ Irrelevant. Electronically metered fuel systems compensate for altitude (less dense air). It's not like the ol' carbureted days.
I lean to 'plugs/coils as well.
Old Oct 12, 2009 | 11:41 AM
invasion08's Avatar
I say check you coils ans plugs. Also run a can of BG44K fuel system cleaner. And then search about Premix.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
cschoeps
Aug 6, 2015 12:44 PM
dbarber
Jul 25, 2015 01:34 PM
