midpipe question
Old Oct 6, 2009 | 09:26 PM
stevenjs31's Avatar
midpipe question
When i talked to the mazda dealer he said if you take off the catalytic convertor it voids the warranty on the engine because the of the o2 sensor. Is there anyway to attach the o2 sensor to an aftermarket midpipe and does it stil void your warranty?
Old Oct 6, 2009 | 09:27 PM
mysql101's Avatar
the o2 sensor responsible for closed loop monitoring is mounted in the manifold, not the midpipe. The midpipe has a rear sensor that only detects if the cat is working. If there is no cat, you don't need the rear sensor.
Old Oct 6, 2009 | 09:28 PM
xun4gvn4everx's Avatar
True love is blue x2
You can try and fake out the second 02 with a spacer in the bung hole. But, this works for some and not for others. As for your warranty, if something happens just put the cat back on and erase your ECU. Problem fixed.
Old Oct 6, 2009 | 09:31 PM
stevenjs31's Avatar
thanks that helps
Old Oct 8, 2009 | 06:39 AM
littlenastymf5's Avatar
Wait.. If i bought an exhaust and then by adding the midpipe it would void the warrenty? or am i just reading it wrong
Old Oct 8, 2009 | 06:46 AM
chino0314's Avatar
yup just keep the stock cat incase yu gotta switch it out again!
qtipconnoisseur
Oct 29, 2015 07:19 PM
br0wm
Oct 24, 2015 11:06 PM
yapakanichi
Sep 25, 2015 07:55 PM
yankeepicker
Sep 11, 2015 05:42 PM
