Engine compatibilty 2009 vs 2004 ?
Old Sep 29, 2009 | 03:47 PM
multirotor's Avatar
Old School Collector
I have read here that the 2009 engine is different from the 2004-2008 engine.
The HP has a new part number n3z3-02-200a while the old one has n3h3-02-200a. A quick look at the EPC shows that the rotor housings are new for 2009 but the apex seals are still the same.
The OMP is supposed to be electronic on the 2009 but can the old pump be fitted to the new engine ?
In general: can you put the 2009 engine into a 2004 without too much hassle ?
Thanks !
Old Sep 29, 2009 | 03:57 PM
expo1's Avatar
He's as bad as Can
The 09 has more oil metering nozzles, a 04 OMP wouldn't know what to do with it. You would need an 09 ECU and would have to change the oil cooling lines. The oil filter was moved on the 09's. Since the power is the same there is no advantage to putting an 09 engine into a series 1 RX8.
Old Sep 29, 2009 | 04:08 PM
multirotor's Avatar
Thanks.
Not looking for more power but more reliability.
Changing the front cover could solve the OMP issue but if there are no internal engine differences, it wouldn't be more reliable.
I will check a few more vital parts in the EPC.
Old Sep 29, 2009 | 04:09 PM
expo1's Avatar
He's as bad as Can
Then getting a sohn adapter and run straight Pre-Mix would be more cost effective.
Old Sep 29, 2009 | 04:39 PM
Old Rotor's Avatar
expo1's idea is what we wish Mazda would do. The rest of us pre-mix....
Panthersn
Jul 13, 2021 06:30 AM
vapor2
Nov 3, 2020 03:38 PM
Redheddude222
Aug 24, 2015 09:14 AM
Mr.Durden
Aug 12, 2015 02:21 PM
vetteor8
Aug 9, 2015 05:56 PM
