best place to run cable through firewall
Old Sep 27, 2009 | 10:08 AM
KiddG's Avatar
Hi Folks,
I've had a problem with my auto headlight levelling system for a while now.
Thought it was about time to sort it out. After testing both sensors, the front one
was found to be well f*cked. So much corrosion and one connecting pin broken off!
Anyway, I've descided to replace it with a variable resistor and mount this on the dash for manual control. I removed all the mechanical parts and ran the cable
back up into the engine bay. At the moment I just connected the Resistor to the end connector....Spot-on everthing is now working fine. Headlights raised up to normal position and warning light on dash now out! :-)
My problem now is how to extend the cable through the firewall to the back of the dash. Anyone have a suggestion the best/easiest route to do this ?
Thanks in advance,
G
Old Sep 27, 2009 | 10:12 AM
Alexb's Avatar
desperately needs a drop
ya, if you look in your engine bay, and down where the pedals are, there is a huge loom of cables going through this rubber thing poke a hole in that, or push the cable under it. There are some pictures of it floating around here somewhere
nuke0907's Avatar
Never Blend In
just check the stickies on running amp power wires or scroll down to the similar threads.
Old Sep 27, 2009 | 03:09 PM
KiddG's Avatar
Thanks guys, I'll go for the rubber gromet on the drivers side
1st thing tomorrow.
Cheers, G
lawlorjuice
Sep 8, 2015 07:55 PM
TheWhiteAce
Aug 24, 2015 12:22 PM
IB Cristina
West RX-8 Forum
Aug 20, 2015 08:52 PM
ShadowGryphon
Jul 29, 2015 05:40 PM
Kangarhew
Jul 18, 2015 08:27 PM
