Please help reg Alarm
Old Sep 25, 2009 | 05:11 PM
aa10's Avatar
Exclamation Please help reg Alarm
oky, i have installed a remote starter (add on), this off course includes a bypass module for the transponder and the car starts fines with he remote starter . however when ever i lock the car with he key less entry (the OEM alarm) and start the car remotely, the alarm goes off but the car starts fine..
i looked on three different sites, which says
site 1;
Factory Alarm Disarm Wire (-): Green/Red
Factory Alarm Disarm Wire Location: In Drivers Kick Panel
site 2
FACTORY ALARM DISARM GREEN/RED (-) IN DRIVERS KICK PANEL
so i trying to find the Green/RED wire but i cant find it ?? any idea where its located or in which area i should look??
Old Oct 10, 2009 | 06:16 AM
tksnobords's Avatar
TK
check out my thread...
https://www.rx8club.com/series-i-interior-audio-electronics-24/rx8-wire-colors-locations-177199/
Disarm (key) 18ga. Green/Red (-) @ 0 ohm in driver’s door harness (extended pulse will unlock all doors)
you can test this wire by putting a probe on the wire., then unlocking the driver door with the key until the wire shows a change. i dont remember if it is negative or positive though. make sure you test it afterwards by setting off the alarm. i tapped the wrong wire the first time. it tested, but didnt disarm the factory alarm. anyway....let me know how it goes.
Old Oct 11, 2009 | 02:28 AM
aa10's Avatar
hi,
first off, thank you for your reply... but what i did is trace the wire from the door and i finally found it...the good news is that the alarm will disarm but it also unlocks the door.. which is more than what i was wanting to do
right now, i thinking of building a bord that will lock the door right after it unlocks it...unless you know a way of disarming the alarm with out opening the door?
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
gt4uk
Sep 20, 2015 07:19 PM
gt4uk
Sep 20, 2015 11:41 AM
cgrichie
Sep 19, 2015 07:03 PM
nivong
Sep 2, 2015 07:54 AM
