Fluid clutch reinforcement bracket
Old Sep 20, 2009 | 10:32 PM
Frosty288's Avatar
n0 pants
Just chiming in on my experience with the Fluid clutch reinforcement bracket (iirc made by mazsport)
My clutch bracket, was destroyed. Obliterated almost, but I didn't know this fully until I pulled the assembly out of my car. At the moment, I wasn't able to buy a whole new assembly. It's a good thing I didn't!
Though it was a huge PITA (every time I pushed on the threads to put the bracket back in the car, they'd get pushed back to the firewall) Which took hours, until my significant other held the piece moving from inside the engine bay.
However, the engine start sensor (for the clutch) Wasn't depressing fully, so I had to mod the trigger a little so it would engage enough to be able to turn the engine on. Otherwise, this bracket is almost a work of art. It's about a 1/4" thick, reinforces in all of the right places, and my car feels better then ever when shifting. I adjusted the pedal at the same time, and it's night and day. Sometimes I used to grind, have trouble getting it in gear, reverse especially. After this install everything's fixed. Best of all, NO more squeaking!
Old Sep 21, 2009 | 03:19 PM
05shinka's Avatar
Bad Company, Till I Die
I had problems with the threads going back into the firewall also... other than that... perfection!
Old Sep 21, 2009 | 03:55 PM
Huey52's Avatar
Registered Zoom Zoomer
Yep, you definitely need to wedge something between the slave cylinder and the upper strut housing on the engine bay side of the firewall, or have an assistant.
The starter interlock switch is easily over compressed, but it may be pulled back out.
Other threads discuss all this btw. It's always good to research before you mod. Most likely someone has already faced all the trials and tribulations and has good suggestions.
Congrats on your proactive/preemptive effort!
Old Sep 21, 2009 | 04:04 PM
kersh4w's Avatar
Hit & Run Magnet
this thread +1
Old Sep 21, 2009 | 04:07 PM
StormyWankel's Avatar
EVOLVChicago.org
My clutch pedal is fine and dandy, but this reinforcement bracket is definitely on my shopping list
Old Sep 21, 2009 | 04:19 PM
souljamcdiddy's Avatar
My pedal has been squeaking for about 2 yrs now in my 05 lol. One day I'll break down and buy this reinforcement. Hopefully that day will come before it snaps.
Old Sep 21, 2009 | 04:27 PM
Huey52's Avatar
I put it off for awhile too, because I knew it was going to be a pain working under the dash - and it was. But glad I finally got it done on my '05.
Old Sep 21, 2009 | 11:00 PM
kersh4w's Avatar
Hit & Run Magnet
do it before it snaps....
do you wait until your engine seizes to replace the oil?
Old Sep 21, 2009 | 11:04 PM
Race Roots's Avatar
Former Sponsor
Fix the link
http://raceroots.com/index.php/produ...cessories.html
We offer the complete assembly with it installed as well
Glad you guys are loving it.
Old Sep 23, 2009 | 04:06 PM
savedsol's Avatar
Carbonormous
How fast is your free shipping. ie. If I order today and am in Chicago...
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
ShellDude
Oct 1, 2015 09:55 PM
XianUnix
Sep 29, 2015 03:48 PM
