Cheaper alternative to metra upgrade cable
Old Sep 20, 2009 | 08:09 PM
natan's Avatar
I did what was stated here:
http://www.mazdas247.com/forum/showthread.php?p=4688300
You can get the cables from:
Digikey
Mouser
Copied over the instructions to modify the cable are:
the cable to have going from the inside of the board to the outside Black,Yellow,Orange,Red in that order leave all other wires loose.
Just make sure you orient the cable so the black wire goes into the ground of the board. You should be able to ohm this out by looking at the negative polarity side of the large tantalum capacitor (the side without the stripe). You could also ohm it out to the vehicle ground connection I believe. This should allow you to properly orient the connector. Then you can just follow the instructions in this thread:
https://www.rx8club.com/series-i-interior-audio-electronics-24/metra-kit-update-need-cable-look-here-172024/
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Quiggs321
Sep 30, 2015 05:34 PM
Learners_Permit
Sep 27, 2015 07:38 PM
