problem :(
Old Sep 19, 2009 | 01:16 AM
speedy-8-ball's Avatar
and ill ride till i die..
problem :(
i own a 2005 mazda rx8. 32000 miles. i brought it in last week to get it painted and the guy moved it early in the morning, was pretty chilly too, and he turned it off right away. he calls me later asking if there was a trick to turning on my car because it wouldn't start. i immediately thought it might have flooded. i have tried many things to get it going. we hitched and pulled the car and and it wouldn't start. i did the mazda manual way and didnt work. i pulled the fuses and that didnt't work. i even bought new sparkplugs and nothing. IDK wut to do?? can it still be flooded or something else?? i also cranked the car while the plugs were out so that the crap that was in there could have come out. some stuff came out, i clean the holes, and i put the plugs back in but still nothing. my engine light stays on when the key is on the ON position. the car cranks and cranks but won't start. and yes my battery is nice and charged. any tips??
_________________
Old Sep 19, 2009 | 01:56 AM
first make sure your plugs are not FOULED.
then go remove the the vacuum nipple cap on the Lower Intake Manifold, put a tube to it. at the other end dip it into a cup of Engine oil or 2 stroke Premix.
Pull the Fuel pump fuse and go crank your engine, if you do it right the vacuum should suck the engine oil in and your car should start for a second or 2 until the fuel burns up.
then put everything back and start your car.
or you can always try to push start it.
Old Sep 19, 2009 | 01:59 AM
then go open the vacuum nipple on the Lower Intake Manifold, put a tube to it. at the other end dip it into a cup of Engine oil.
thanks. i think i've seen a diy somewhere on here for that. i also did try push starting it but nothing :/
Old Sep 19, 2009 | 02:00 AM
Jon316G's Avatar
Grasshopper
I just want to clarify that he said LOWER intake manifold.
I just had bad visions of people using the nipple on the upper intake manifold behind the throttle body for the VFAD.
That would be a bad bad thing.
Old Sep 19, 2009 | 02:06 AM
could it be something worse than simply flooded?
Old Sep 19, 2009 | 07:31 AM
rotarykillz's Avatar
Rotary Freak
not likely..they can just be a pain to get unflooded. my bro flooded mine while I was out of town for work. He tried several different things, but the thing that got it was hooking up jumper cables, holding the gas pedal down and cranking for 5-10 seconds, letting the starter rest, repeat 3 or 4 times then try starting without the gas pedal pushed down. I guess the gas pedal being depressed 100% shuts down fuel during start too.
There was a DIY for this procedure too. May have to keep trying it up to 10-15 times before it will clear out.
Old Sep 19, 2009 | 08:06 AM
after you de-flood your car, chances are some of the fuel will end up inside your CAT. so when you start your car. its gonna start cooking it ...
you might want to look into that
Old Sep 22, 2009 | 11:50 PM
you guys would never believe the problem!!
Old Sep 22, 2009 | 11:52 PM
nothing worked and today was just standing there trying to think of ideas. then thought about maybe adding some fresh gasoline and see if that would help at all. when i started adding gas, it all leaked out on the floor. turns out that the car ran out of gas somehow, and somehow the hose to the gas tank was disconnected . so fricking confused.. haha. but now got it fired up and running and shouldn't be too long before ill have it on the streets .
Old Sep 22, 2009 | 11:58 PM
Jon316G's Avatar
Grasshopper
Are you referring the fuel filler neck or a disconnect in the engine bay (like the one by the brake booster)?
Old Sep 23, 2009 | 12:06 AM
im talking about the big rubber hose that is connected directly to the fuel tank (behind the left back wheel). dunno what its called though
Old Sep 23, 2009 | 12:08 AM
Jon316G's Avatar
Grasshopper
Damn... that's weird!
Old Sep 23, 2009 | 12:11 AM
tell me about it!! at least it didnt cost any more money to just put the hose back on and add some fuel . now purrs like a kitten with the hymee exhaust
Old Sep 23, 2009 | 01:21 PM
Sounds like somebody in the shop shiponed your gas.
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
