where can i find a constant 12V in the RX8 interior
Old Sep 11, 2009 | 07:25 AM
westwing's Avatar
Hi guys
i need to find a constant 12v in the rx8 interior does any1 know where i can find it?
Old Sep 11, 2009 | 07:28 AM
ZumnRx8's Avatar
RX8 & RX7 owner
the cigaretter lighter.... taking the assembly apart tapping into the cigaretter lighter power line....
Old Sep 11, 2009 | 07:24 PM
Juice's Avatar
I made some poos
Thats not constant, constant being always on. The lighter is switched, as in, only on when you turn the key.
There is a constant 12v in the radio harness to keep the programmed radio stations in memory.
Old Sep 11, 2009 | 07:39 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
You can always go to fuse box with a meter........with the car off and find it!
I think one side of the room fuse(15a) is always 12v isn't it?
Old Sep 11, 2009 | 07:49 PM
atl8's Avatar
The accessory socket in the center console has a green wire attached to it that's specifically for 12v accessories
Originally Posted by westwing
Hi guys
Old Sep 11, 2009 | 07:52 PM
Mazurfer's Avatar
I could be wrong, but that is switched....isn't it? Key in and on ACC for it to get there?
Old Sep 11, 2009 | 07:53 PM
Easy_E1's Avatar
That falls under the switched power category too. Swoope has the best suggestion.
Old Sep 12, 2009 | 01:10 PM
atl8's Avatar
oops...you're right. The key does have to be switched to at least the first position to get power there. That must not be the green wire I was thinking I'd tapped into before. The largest gauge green wire you see by the fuse kick plate? But as suggested put a multimeter to it first.
Old Sep 12, 2009 | 01:17 PM
TotalImmortal's Avatar
Also a constant in the stereo wiring for the stereo memory.
Old Sep 12, 2009 | 01:26 PM
rexybrad's Avatar
what are you wanting to run? and why does it have to be constant? depending on what you want if for it may drain your battery
Old Sep 16, 2009 | 09:47 PM
Room fuse in the fuse box.
http://www.amazon.com/Littelfuse-FHA.../dp/B0002BGELQ
Old Sep 16, 2009 | 11:29 PM
hakuna matata!
nothing better then running it directly from the battery
Old Sep 16, 2009 | 11:39 PM
Jon316G's Avatar
Grasshopper
... with an inline fuse preferably
Old Sep 17, 2009 | 06:30 PM
Mazurfer's Avatar
Very true, but not if you don't want to mess with the extra wiring and running it through the firewall. Also....needs and inline fuse(as Jon316G points out) either way.....from the battery or from anywhere where it is constant.....like one side of the room fuse.
Old Sep 17, 2009 | 06:31 PM
Mazurfer's Avatar
He never said, but I assume it's something with it's own switch and he won't forget to power it off!
Old Sep 17, 2009 | 10:10 PM
DarkLord7854's Avatar
Software Engineer
Chiming in randomly but mine's always got power in the cupholder compartment.. the cig lighter on the center dash is switched though.
Old Oct 15, 2009 | 04:42 AM
westwing's Avatar
thank for all the info n tips guys
is for my car pc btw
Skyl3r
Dec 2, 2019 04:51 PM
Crazy.8
Apr 18, 2017 03:17 PM
stickmantijuana
Jul 19, 2015 10:33 AM
