Spark plugs and coils
Old Sep 9, 2009 | 06:08 PM
yellowRX's Avatar
Piston? What's a piston
Hey everyone, I just got back from the dealer and it seems like i need to replace my plugs can coil packs. It's gonna set me back about $700.00 bucks My question is, anyway to maintain these so I don't have to go through this again next year? I only ask because I just replace them a bit over a year and Mazda said it's one month past my warranty I think this is stupid if it keeps being an issue.
Old Sep 9, 2009 | 06:10 PM
mkmike103's Avatar
Kind of odd they would go bad after a year. You should do it yourself and save some change What's the issue with the car, that the plugs and coils need changing again?
Old Sep 9, 2009 | 06:12 PM
I8U's Avatar
I8U
With a small amount of searching you can find the parts you need from vendors here under $200. Then do the work yourself and save on all the labor costs...take about an hr for someone with little mechanical skill to replace plugs and coil.
BTW mike, I've had coils and plugs go bad within a month before...most here usually change their coils and plugs every yr no matter what, I know I did when I was running stock coils.
Old Sep 9, 2009 | 06:18 PM
invasion08's Avatar
You can change them yourself for around 180 plus shipping. And it is very simple to do
Old Sep 9, 2009 | 06:20 PM
yellowRX's Avatar
Yup, I need to change them again.
Old Sep 9, 2009 | 06:21 PM
yellowRX's Avatar
thanks for the tip guys. I guess this is common with the 8. I'm gonna head to the do it yourself part of this forum and see if I can learn about changing them.
invasion08's Avatar
Ignition Coils (4) http://www.finishlineperformance.com...cat=338&page=2
Leading Spark Plug (2)http://www.amazon.com/NGK-RE7CL-Lase...2538415&sr=8-2
Trailing Spark Plug (2) http://www.amazon.com/NGK-RE9BT-Lase...2538415&sr=8-1
Old Sep 9, 2009 | 06:26 PM
invasion08's Avatar
Or you can upgrade to a BHR Ignition System.
Old Sep 9, 2009 | 06:32 PM
yellowRX's Avatar
WOW thanks invasion
Old Sep 9, 2009 | 06:33 PM
invasion08's Avatar
no problem
Old Sep 10, 2009 | 07:36 PM
saveferris4231's Avatar
here's where i ordered my coils from. $28.43 each and free shipping. best i've found yet.
http://www.buyourmazdaparts.com/inde...t_detail&p=815
Old Sep 10, 2009 | 09:21 PM
tmak26b's Avatar
When you change the coils, remove the intake silencer rather than the whole intake box. It will take 1/3 the time, jack up the LF and remove tire to do spark plugs. Also buy yourself 3 long extensions, you will thank me later
Old Sep 24, 2009 | 09:45 AM
jeanosh's Avatar
Hi, does anyone know if there is a sequence numbering to the coils? CEL code indicates that there is failure at No. 4 Coil (something like that), and I dont know which is which. The one nearest to the windscreen is Coil No. 4?....
RevMeHarder
Jun 1, 2026 02:30 PM
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
WranglerFan
May 31, 2022 07:51 AM
TeslaMSI
Dec 10, 2015 01:10 AM
