View Full Version : connecting a car kit to the stereo
adainty 01-08-2004, 05:39 AM Getting a company to install a nokia car kit into my RX8, the kit can be connected to the stereo system to mute the music and play the audio of the call though the speaker system.
has anyone else done this??
does anybody know the make and model of the stereo used in the RX8 and if it has a internal amplier in the head unit?
adainty 01-09-2004, 02:02 AM Is there not one person out there that knows the make and model of the stereo?
Come on guys this is where we are ment to share information with each other.
Charles R. Hill 01-09-2004, 04:50 AM I am not sure of the make and model of the head unit. I used to do some work repairing Sony c.d. players in the Automotive division. Most of our stuff came from Ford Motor Co. so that might be a possibility. I have the Bose speaker system in my RX and it sounds like the power amp is outboard and always switched on when the key is on. If you listen close with the engine off you might hear a bit of amp idle noise. My guess is that the factory audio system is of a modular variety, which means there should be aux. inputs and control circuits for the cell kit of which you speak. Hope this helps you.
Good Luck,
C.R.
Sputnik 01-09-2004, 11:49 AM Originally posted by adainty
Come on guys this is where we are ment to share information with each other. Do a search. That information has been mentioned several times already.
---jps
OverLOAD 01-10-2004, 07:57 PM The RX-8 HU is not friendly to modification. Good luck for them to do it. It will be expensive and time consuming for them to do so.. most probably, but if they find a way to do it, even at great expense, I would be curoius as to the approach that they take.
Regards,
OverLOAD
mhopley 01-11-2004, 01:40 AM Originally posted by adainty
It is always harder fit a car kit to the Bose systems with amplifiers but it is possible as there is a solution for the TT.
Dashmount (http://www.dashmount.co.uk) sell a mute lead for the RX-8 but no one has used it yet. The system is very similar to the Mazda 6 with the Bose system. The head unit has line level outputs to an amplifier that is under the rear parcel shelf.
I ended up fitting my car kit with a seperate speaker as I did not want to risk damaging the head unit.
Mark
bobclevenger 01-21-2004, 07:10 AM Originally posted by mhopley
Thank you for the link to Dashmount. I have contacted them just tonight and requested information on purchasing their mute lead harness. If and when I get it I shall let you know how it works out.
adainty 01-21-2004, 07:58 AM Just been speaking to the sale manager for BOSE in the UK who has advised me that an adaptor will be releast soon so that this will be possiable. got to call him back next week once the contact manager for mazda is available.
Said that the Nokia kit will work once the adapter is available as the head unit was made especially for the RX8 and mazda need to give the OK for them to use it to sell to the public market place.
bobclevenger 02-02-2004, 05:09 AM I just installed the kit I bought from the Dashmount company in the UK. It required a few minor modifications, notably changing one connector and changing the pin arrangement on another -- nothing anyone who is technically savvy can't do.
The unit works very well. When the phone is active the stereo mutes and the phone plays through the 8's speakers.
Oh, there is no cutting required to the car's wiring! Everything is plug-in.
The kit is called a "dashlead" and they do ship to the US, but it's not cheap! About $70 with shipping, but the stuff works and it is good quality.
I've been told that they have a "non-damaging" cell phone mount for the 8 now too.
sixspeed 02-02-2004, 08:07 AM Bob,
I have the mute lead from Dashmount , but haven't fitted it yet! Can you tell me which pins you had to swap to get this to work?
-andy-
bobclevenger 02-02-2004, 03:19 PM Originally posted by sixspeed
Bob,
-andy-
You may not need to do any swapping. The folks at Dashmount told me it was due to UK vs. US specs on the Motorola car kits. BTW, use their "method 1" for the mute connexion.
adainty 02-05-2004, 10:34 AM Thanks, bob!
TheDosDog 02-22-2004, 03:00 PM I just finished installing Dashmount's mute lead. Works great and no modifications were require to the 8s wiring. As BobClevenger alerted me, the mute lead is not designed to play through the Bose system amps. Therefore you have to step down the signal a bit. Bob provided the specs for a voltage divider to accomplish this. I used a 100k ohm 1/2 watt resistor in series with a 1k ohm potentiometer adjusted it to 220 ohms. Connect the resistors across the speaker output of the car kit. Connect the mute lead audio input across the 1k pot only. After the install you can fine tune the volume. Volume is controlled by the phone and the pot and is not effected by the 8s audio controls. The radio does not need to be on to use the phone but the ignition has to be on or in the accessory position to energize the amps. I'm getting a little engine noise in the speakers when using the phone but I can probably eliminate this with a filter. Now, when I make or receive a call, the radio mutes and the phone plays clearly through the sound system.
bobclevenger 02-22-2004, 04:20 PM Hey DosDog, good to hear you got it working.
I also have a bit of noise in the amps when using the phone, but I'm just living with it. Let me know if you get a filter that works, OK?
TheDosDog 02-22-2004, 05:42 PM Yep, filter killed the noise. I installed a 20 amp in-line noise filter (picked up at the local autoparts store) on the red power lead going into the motorola control unit.
Omicron 02-22-2004, 06:35 PM This is a sweet mod folks. Now I have to hunt down the car kit for my Motorola T720 and pay Dashmount a visit.
Bob or DosDog, I don't suppose either one of you would like to put together a "DIY" thread on installation and the extra components needed would you? This is a definite candidate for the DIY forum. You do it, and I'll put it there in a heartbeat. :D
bobclevenger 02-22-2004, 06:44 PM Thanks DosDog-- that filter's next on my list.
bobclevenger 02-22-2004, 06:50 PM Originally posted by Omicron
DosDog -- your install is the newer; did you have any of the issues I had except for the audio level?
I'm sure that between us we can put together a DIY for this. Of course it requires a rather pricey custom cable assembly from England to begin with, but it's definitely worth it if you use your cell phone in the car a lot.
TheDosDog 02-22-2004, 08:22 PM Bob - There were no other issues. The cable included a short pigtail that reoriented the power input to the Motorola control unit. I spliced the filter into this pigtail. The pot I used (radioshack $1.99) was a 15 turn bar type that I was able to solder and integrate into the harness which placed the adjustment on the audio out cable just a few inches from the controller. Then I just had to splice in the Motorola audio connector from the cart kit. The harness cost me just over $90 with shipping (that's inflation) but still more than worth it.
TheDosDog 02-24-2004, 01:01 AM Parts used:
Dashmount Lead
100k 1/2 watt resistor
1k 1.2 watt potentiometer (15 turn)
20 amp noise filter
Total cost was ~ $100
Here is schematic of voltage divider required for 8s with Bose:
msrecant 02-24-2004, 10:53 AM Dumb question. Could the Dashmount Lead be used to provide a generic AUX input to the RX-8 sound system? I understand that Dashmount feeds directly into the Bose amps so that volume control would have to be provided by the accessory (and not the RX-8 volume control).
watte?? 02-24-2004, 01:18 PM I've just bought me this mute-module from QuBit.
(www.qubit.dk => this company is located in Denmark, Europe)
It is especially designed for the BOSE-systems used in the Mazda's. (Mazda6, Mazda3, Mazda Rx-8)
Just plug and play ! No need to cut any wire !!!
You have the option to select only front or front + rear speakers.
Speaker-signal from mobile-phone is converted to audio-line signal from wich you can adjust the volume.
I will be installing this to use with my Nokia-carkit as soon as my new Rx-8 will be delivered.
Question :
with the mute-systems that you use (dashlead etc), when the system mutes, does "MUTE" (or something like that) appear on the radio dash LED ?
I'll post some pictures as wel as a technical sheet (2 pages).
PAGE 1 :
watte?? 02-24-2004, 01:20 PM PAGE 2 :
watte?? 02-24-2004, 01:21 PM PICTURE :
bobclevenger 02-24-2004, 02:03 PM This looks like the same system as the Dashlead, but with improved electronics in the "black box".
Please let us know how well it works when you get your 8.
No, the display on the radio does not change when a phone call is in progress.
I wish I'd found out about this one sooner!
mdmaclean 02-28-2004, 08:48 AM What kind of microphone setup do you use with these systems?
TheDosDog 02-28-2004, 09:34 AM The system in my 8 is Motorola Nextel. The wired microphone is part of the car kit. I located it at the edge of the headliner between mirror & visor.
TheDosDog 02-28-2004, 11:43 AM Here's where mine is located.
mdmaclean 03-11-2004, 03:45 PM Originally posted by watte??
Did you connect this to a car-kit for your phone, or just buy a microphone somewhere? It kind of looks like it does everything you need except provide a mic.
watte?? 03-12-2004, 10:15 AM You need to connect it to a complete carkit (black-box, microphone, phone-socket) to meke it work with your phone.
The Qubit-unit itself does not work with your phone directly.
(it is designed to work with carkits)
ZoominRex 03-12-2004, 12:27 PM Is the qubit unit compatible with the sony ericcson hbc-30 carkit or does thing only work with Nokia units?
watte?? 03-12-2004, 12:51 PM Should work with all type of mobile-phone carkit.
If you want to be sure, contact Qubit (mail or phone) and ask them. System looks pretty good though.
As soon as I have it installed in my 8, I will post pictures etc.
ZoominRex 03-12-2004, 03:54 PM Do you guys know if the Sony carkit will work with a nokia phone?
watte?? 03-13-2004, 03:25 AM Don't think so...
ZoominRex 03-15-2004, 12:57 PM how much are the qubit units? and where did you order yours? Is there anywhere to get them online?
watte?? 03-15-2004, 02:32 PM As I live in Europe, I bought it directly from a dealer nearby.
I think it is best that you contact Qubit directly to ask for shipping to USA. Don't think it will be a problem.
(Then you can also inquire about the type of mobile carkits it works with. (I would say probably most common are no problem.) )
Check out their site : www. qubit.dk
The company is located in Denmark, Europe
mdmaclean 03-15-2004, 08:56 PM Originally posted by ZoominRex
I have recently sent them a e-mail but have not received a reply. It is hard to tell if they do direct sales, or even sell to North America.
Please post if you find a place to get the unit here.
ZoominRex 03-17-2004, 11:34 AM same story here. I emailed them 3 days ago and still no response.
mdmaclean 03-17-2004, 08:00 PM Originally posted by mdmaclean
I received a reply today.
Hi Mark
Thanks for your query.
The product you need is product number 84-00804
For price and delivery please contact :
ProClip USA
Toll free: 1 800-296-3212
Tel: (+1) 608-838-8950
Fax: (+1) 608-838-8949
E-mail: info@proclipusa.com
or
Cellular Products Canada
Toll free: 1 800-292-2210
Tel: (+1) 416-712-4798
Fax: (+1) 905-509-8808
E-mail: proclips-canada@rogers.com
Best Regards
Thomas
QuBiT A/S
ZoominRex 03-19-2004, 10:46 AM Thanks Mark!
ZoominRex 03-19-2004, 12:16 PM Looks like I will be going with the Dashlead unit. I called proclip today and was told the unit is about 180 bucks which costs more than the actual carkit. Do you think you guys can provide a step-by-step tutorial of how you guys got the dashlead unit to work? It would be GREATLY appreciated.
TheDosDog 03-19-2004, 12:31 PM If you have Bose you'll need to modify the cable. Once you get it let me know. I'll show you what you need to do.
ZoominRex 03-19-2004, 01:22 PM Thanks! I was going to get it installed at my stereo shop anyways. I just wanted to provide them with instructions on how to do it properly with the Bose system.
TheDosDog 03-19-2004, 02:25 PM The diagram for the voltage divider is earlier in this thread. I advise installing the Dashlead before the carkit, if it's not too late, since it provides power to the carkit.
ZoominRex 03-19-2004, 03:19 PM ok thanks, i'll print out that picture and the description you posted earlier and give it to the guy doing my install. Thanks!
ZoominRex 03-19-2004, 03:25 PM I've been trying to contact dashmount but they haven't responded in 2 days. Is there anywhere else where I can purchase the dashlead?
TheDosDog 03-19-2004, 03:58 PM Try this:
Steve Taylor
0044 208 391 1911
Steve.Taylor@dashmount.co.uk
QuBiT 06-03-2004, 06:26 AM QuBiT has new information for the RX8 owners:
***moderator edit***
***QuBiT should contact moderators or admins so that he can be made aware of the rules for advertising before QuBiT gets banned with prejudice***
QuBiT 06-07-2004, 08:59 AM Sorry I was just trying to help.
