Ecu/years
Old Sep 3, 2009 | 11:58 PM
CodyD's Avatar
Cool Ranch Dorito
Ecu/years
the ecu in my 2004 rx8 took a s+++ yesterday. can i use any year through an '08 ecu?
thanks in advance
Cody
Old Sep 4, 2009 | 01:05 AM
MazdaManiac's Avatar
Depends on your relationship with your dealer.
Old Sep 4, 2009 | 05:58 AM
thanks in advance
Cody
wow,
all that info..
it is a yes and no question.. yep, you can use any ecu from 04 to 08.
but getting someone to program it to work is the issue.. and it did not take a ****.
you messed some **** up..
Old Sep 5, 2009 | 12:25 PM
CodyD's Avatar
Cool Ranch Dorito
I didnt do anything to the car. I was driving and everything shut off on me, car threw itself into security. Shop says the ecu's fried. So if i get a different ecu, it will have to be programmed? what kind of programming will it require?
Old Sep 5, 2009 | 12:34 PM
expo1's Avatar
He's as bad as Can
The kind that only can be preformed by a Dealership. You should stop by there Tuesday with 2 dozen doughnuts and coffee and make some friends.
Old Sep 5, 2009 | 12:46 PM
TotalImmortal's Avatar
Sounds like a good reason to put in a stand alone to me.
Old Sep 5, 2009 | 01:29 PM
StealthTL's Avatar
Metatron
Shop?
As in 'not a dealership' shop?
You can't go by what a local mechanic knows about that ECU - there are multiple fuses involved, might just be one of them.......
S
