Before I take it in to the dealer... (power loss/noise)
95% of the time my car is fine. (2005 GT)
When I have power loss, I get a knocking sound higher than 6K RPM.
I tend to get the power loss more often during hotter days. (25C+)
Can fuel starvation from an overheating fuel pump cause that sound?
I recent have changed out coils/wires/plugs.
Should I try getting the fuel pump replaced first or straight off ask for a compression test.
http://www.finishlineperformance.com...4-08-1924g.pdf
i can say i have a bit of knowledge with this..
what you describe is more like dry apex seals..
the reason i asked about the last recall was they tend to do a vacuum test..
if you are still under warranty. and this is covered by the 8 year 100k mile one in the usa.. i think it is the same in canada, eh.
take to the dealer, say the car has a loss of power. that likely will get you a vacuum test and a compression test. if it fails, and it likely will with what you describe.
you get a carbon cleaning and retest.. that might fix the issue..
if not new motor time..
btw, if under warranty dont let them try the diagnostic fee crap..
Shankapotamus3
Mar 14, 2021 03:53 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
