View Full Version : v-leds running lights
Hesselrode
08-31-2009, 10:52 AM
do I need to put a resistor in line with the running lights the little lites in the headlamp unit? anyone had any problems with these? I am also running the third brake light led and the 1194 leds or whatever they are in the brake lights, i am causing the traction and abs lights come on where do i need a resistor and how much? with the normal third brake light it doesn't do this but with all leds it does.. can i just put one big resistor in the third brake light or do I need in all brake lights?
Aipex8
08-31-2009, 02:20 PM
No resistors needed for the parking lights. Unfortunately, I used the high power LED bulbs for my brake lights and didn't end up getting any errors from having all LEDs. V-LEDS did suggest the following resistor before I purchased mine.
http://www.v-leds.com/BlinkerWarning-Fix/Warning-Light-Fix/LED-BULB-OUT-WARNING-p4481145-1-3.html
You should just need one, and you should be able to put it on any of the brake lights, I would suggest the center one.
Hesselrode
08-31-2009, 05:00 PM
thanks aipex8 i am using the replacement third brake light..
