xvickx
08-30-2009, 08:26 PM
Are there any other dual resonated mid pipe that's similar to mazsport's. Thats available on the market?
View Full Version : Midpipe Q xvickx 08-30-2009, 08:26 PM Are there any other dual resonated mid pipe that's similar to mazsport's. Thats available on the market? invasion08 08-30-2009, 08:45 PM Yes Racing Beat sells one. http://www.racingbeat.com/photos/16221.jpg http://www.racingbeat.com/FRmazda4.htm Jon316G 08-30-2009, 09:08 PM ^+1 I've heard the Racing Beat side-by-side with the MazSport (same cat-back too)... can hardly tell them apart. xvickx 08-30-2009, 09:34 PM woohoo thanks for the quick response guys! Bighurk 08-30-2009, 09:46 PM corksport is also making one that should be coming out september? pdxhak 08-30-2009, 11:18 PM Corksport has 3 midpipes coming out. A single res, dual res and a single res with a cat. Bighurk 08-30-2009, 11:49 PM Corksport has 3 midpipes coming out. A single res, dual res and a single res with a cat. do you know what size the pipes are? i looked on their blog and it said 60mm (2.36in). Just wanted to make sure pdxhak 08-30-2009, 11:56 PM Unless they change it then I assume it is going to be 60mm |
