I shifted from reldine in 3rd to 2nd. Is there any problems that could happen.
Old Aug 29, 2009 | 08:40 PM
RX-8GT6spd's Avatar
RX-8 Grand Touring Owner
I shifted by accident from redline in 3rd to 2nd. The rpms were past 10,000 and I immediately through it into neutral. After that i went on driving the car and it seemed fine but it scared the hell out of me when i smacked forward. If this has happened to you please post if any problems that happened or if you know any info about this please post.
Old Aug 30, 2009 | 11:43 AM
costello's Avatar
If it runs fine then it should be ok. If you start having problems then you did some damage. No rocket science there. You're probably ok though since you took it out of gear quickly enough. I've over-revved piston engines and they've been ok. Just depends how long it was over-revved.
Old Aug 30, 2009 | 12:02 PM
RX-8GT6spd's Avatar
Ok thanks, it was only like 2 to 3 seconds. It ran fine after the accident but ill keep a look out for anything.
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
nowakm99
Oct 9, 2015 07:10 AM
TheRedRotor
Sep 12, 2015 07:42 AM
