View Full Version : RX-8 Wiring loom for Sat NAv
BlueNev
08-29-2009, 03:53 AM
Hi Paul
I’m in the uk but a member of rx8club, and am working on installing the RX-8 sat nav, using bits from a car that had the factory fit sat nav into my non sat nav car (231 - 2007).
I am getting as much of the loom that can be taken out of the donor car, which is having a drastic weight reduction without it losing functions other than radio, aircon, and satnav.
This has been done by people on the Forum, but need access to just the wiring components. I have the wiring diagram to find the parts needed, so will be able to try to ask for right bits. Are these parts you could help with?
Basically, I will need bits of the loom that he can’t give me or is there a kit that you would know how to get hold of???
Cheers
BlueNev
allenfre
02-01-2010, 10:04 AM
[quote=BlueNev;3195870]Hi Paul
I am getting as much of the split loom tubing (http://www.thepartsbin.com/brands/mr_gasket/mr_gasket_split_loom_tubing.html) that can be taken out of the donor car, which is having a drastic weight reduction without it losing functions other than radio, aircon, and satnav.
Cheers
BlueNev[/quote
Does anyone have a diagram for this one? I need to get things done this weekend. I just want a diagram to be my guide.
