View Full Version : Aftermarket Alarm Window Modules
huhsler
01-07-2004, 08:54 AM
I just got the Compustar alarm system installed in my RX-8 and it is shweet!
However, I wanted to drop a technical note that my installers discovered.
The Auto-Down driver's window is controlled by both the switch relay and an additional trigger in the driver's window motor. Traditional (i.e. DEI-made) window modules will not work with this motor.
To get remote-window up/down to work, the driver's window motor must be replaced with a stock passenger's window motor. Everything will work fine then. Bypassing the triggers in the driver's window motor did NOT work.
The up-side of this is that both windows will then be Auto-Up-Down through the latest DEI window module.
Just an fyi.
mikeb
01-07-2004, 01:40 PM
thanks for the info
and congrats on the mod
huhsler
01-09-2004, 09:16 AM
Thanks.
Actually, after re-reading my post, I don't think I was clear on that last part.
After the motor is swapped, both windows are Auto-Down using the switches INSIDE the car (just like the driver's side currently). So, that's the nice bonus.
P Daddy
01-09-2004, 10:04 PM
Maybe I'm not reading things right but if you replaced the auto down motor (drivers side) with a non-auto down motor from the passenger side. How do they both become auto down.
Unless the auto down comes from the aftermarket windo controller at this point?
huhsler
01-12-2004, 11:04 AM
That is exactly correct.
For instance, the newest DEI window module is installed between the switches and the motors.
They'll even take a 2 stage window switch input (like the driver's side rocker) to make it auto-down. Otherwise, it will automatically be set for auto-down.
