rx 8 engine failure
Old Aug 22, 2009 | 12:24 PM
bob2's Avatar
rx 8 engine failure
Hi everyone,
My RX 8 engine failed, so i decided to pull it apart to see whats gone wrong.
Well the bearings are knackered the rotor housing look shot!!! The apex seal's are heavily worn!!. One of the rotor housings looks like it has a crack in it by one of the plug holes.
Just looking for opinions on the failure and the causes and what i can do to prevent it.
Old Aug 22, 2009 | 12:37 PM
I8U's Avatar
I8U
I'd say it looks pretty f'd. Happy rebuild!
Old Aug 22, 2009 | 12:40 PM
Old Rotor's Avatar
Please give us all the info on your car.....The service it's had and parts replaced. Model, miles, type of driving it gets(long commutes), fuel used, oil type and consumption, ever flooded, red lined. Just any thing that you can add. Were you aware Mazda extended the warranty too 8yrs 100K.
Old Aug 22, 2009 | 12:41 PM
Easy_E1's Avatar
She looks like she was rode hard and put away wet. Have you ever run low on oil?
Looks like a whole lot of HIGH rpm use. Eccentric Shaft flex on the stationary gear bearings.
Old Aug 22, 2009 | 12:47 PM
olddragger's Avatar
see this things a lot.
OD
Old Aug 22, 2009 | 12:51 PM
fastlaneracing's Avatar
Rotor User
Overheated.
Old Aug 22, 2009 | 02:11 PM
bob2's Avatar
Hi guys
The car (2004 model) did approx 58k and is standard, it was always serviced on time and i checked my oil regulaly the most i ever need was 3/4litre to bring back up to max. I used Fuchs XTR 5w-30 for servicing and top up. The only real problem the car has had is a missfire at 45k approx and it ended up needing coils plugs and leads. It never overheated or had any other problems.
Old Aug 22, 2009 | 02:30 PM
Old Rotor's Avatar
Originally Posted by bob2
Hi guys
Why did you tear it down? Mazda would have installed a new one N/C? I see you have been on here for years.....why...
Old Aug 22, 2009 | 02:34 PM
bob2's Avatar
I'm in the UK and yes mazda provided a new engine but i had to pay for fitting. I asked my dealer if i could have the engine if mazda did'nt want it back, So here it is.
Old Aug 22, 2009 | 02:39 PM
Old Rotor's Avatar
I see no location so now we know......Are you going to pre-mix on your new engine. Is it new or rebuilt(US now gets rebuilt)?
Old Aug 22, 2009 | 03:01 PM
bob2's Avatar
Its a brand new unit. Just don't want it to happen again.
Old Aug 22, 2009 | 05:53 PM
mkmike103's Avatar
Cool pics, thanks for posting them. Sorry that it happened - hope this one lasts you longer.
Old Aug 22, 2009 | 07:03 PM
Old Rotor's Avatar
How often did you change oil and did it burn much. You might want to pre-mix. Did you put the apex seals on a straight edge and see if it is worn more in the center.
Old Jan 20, 2011 | 10:41 AM
mikefives's Avatar
pre mixing oil???i just bought one and am pretty uninformed about it.love the car...any tips on a long life for my rotary?
Old Jan 20, 2011 | 11:20 AM
Beodude's Avatar
BearBlasterExtraordinair!
How often did you run it all the way up to 9,000?
Old Jan 20, 2011 | 11:24 AM
Beodude's Avatar
Go to the "Tech Garage", and read the premixing thread. It's long, but very informative.
Here is another thread that's good. https://www.rx8club.com/series-i-tech-garage-22/my-sneaky-plan-extend-engine-life-series-i-190372/. Also read the "Possible Renesis Engine Failure?" thread. Lots and lots of good stuff in there.
Those three threads taught me a lot.
Old Jan 20, 2011 | 11:28 AM
ken-x8's Avatar
Welcome! Read this thread to catch up on what you need to know:
https://www.rx8club.com/new-member-forum-197/new-potential-owners-start-here-202454/
Pre-mix means adding two-stroke oil to the gas.
Ken
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
Sifu
Aug 30, 2015 10:51 PM
Eirulisse
Aug 15, 2015 12:34 PM
mazdaverx7
Jul 21, 2015 07:31 PM
