For those interested in Race Ramps
Old Aug 20, 2009 | 09:41 PM
Are-Ex-Eight's Avatar
Nice Rotors
Here are some pictures.
Old Aug 20, 2009 | 09:49 PM
nuke0907's Avatar
Never Blend In
are you even lowered?
Old Aug 20, 2009 | 09:57 PM
TopGear8's Avatar
mkuhnracing.com
My front bumper and side skirts are 3.5" off the ground...Think I'll make it?
Old Aug 20, 2009 | 10:07 PM
Nice Rotors
R3 is a lower than typical stock. Rhino's won't work without rubbing.
Old Aug 20, 2009 | 10:09 PM
J8635621's Avatar
Pew Pew Pew
I have the jack ramps or whatever that get the car an extra 6" off the ground so a jack will fit under the car. Awesome products. There are coupon codes if you google.
TopGear8's Avatar
mkuhnracing.com
^Lower than stock yes, would you like to go out and measure the hight of the front lip from ground please?
I'm going to guess about 4.5"
Old Aug 20, 2009 | 10:10 PM
Nice Rotors
Take a yardstick (or tape measure - put it to 3 ft) and then put it right to the edge of your front tire and pull it up tight to your bumper lip. If the gap between the 3ft mark of the tape measure or end of yardstick is 7.25 inches or more off the ground then your fine.
My guess is that you would be fine.
Old Aug 20, 2009 | 10:15 PM
Nice Rotors
Yes I used 10% off. Probably more out there if you look longer.
Old Aug 20, 2009 | 10:16 PM
Nice Rotors
I will tomorrow, I put the ramps away already lol.
Old Aug 20, 2009 | 11:06 PM
pdxhak's Avatar
Official Post Whore
I think he 04-08 with OE lip is like 5.5" or 6" off the ground. Does the R3 sit an inch lower?
Old Aug 20, 2009 | 11:14 PM
chickenwafer's Avatar
Nope
ehhh I still don't think I could make it, I'm slammed and have the MS front
Old Aug 20, 2009 | 11:32 PM
pdxhak's Avatar
Official Post Whore
I doubt I could use the ramps with my lip
Old Aug 21, 2009 | 12:07 AM
-RX8-'s Avatar
takata makes ramps too, i believe they're lower.
Old Aug 21, 2009 | 01:01 AM
Rhino ramps FTW! I'm lowered and have no problem getting up and they are $30.00.
Old Aug 21, 2009 | 01:16 AM
d j's Avatar
d j
hukbong himpapawid
you probably have a stock bumper then, I'm lowered as well with Tsunami front bumper and won't clear the rhino ramps.
Old Aug 21, 2009 | 01:25 AM
Yeah I am.
Old Aug 21, 2009 | 02:19 AM
tiltmode43's Avatar
OMGITM!
OEM jack won't even fit under my car, by far
Pointless post? Yes.
Old Aug 21, 2009 | 02:45 AM
J8635621's Avatar
Pew Pew Pew
http://www.raceramps.com/trakjax.html What I have and it actually raises the car 3". I don't need it yet as I'm only on Koni's+MS springs, but I will need it one day soon.
Old Aug 21, 2009 | 07:10 AM
Chris's Avatar
Turbo Member
I just use a race jack... a lowered 8 with ms sideskirts needs a race jack. it just fits under to the lift spots. perfect fit really. any lower and I would have to park on a 2x4 or somthing
Old Aug 21, 2009 | 08:48 AM
rodjonathan's Avatar
silent assasin
he said 3.5 off the ground dam thats pretty dam low!
Old Aug 21, 2009 | 09:01 AM
dillsrotary's Avatar
jersey fresh
Nothing a couple planks of 4x2's can't fix, thats how we "coasted" mine with s-techs and MS front last year.
Old Aug 21, 2009 | 09:03 PM
dondo's Avatar
100% baller (finally!)
i'm lowered with ms skirts and my race jack doesnt fit. i have to roll it on 2x4s
Old Aug 21, 2009 | 09:31 PM
TopGear8's Avatar
mkuhnracing.com
^Yeah either using 2x4's works or jacking up the rear of the car, then putting a jack stand on the side of the car will get both side wheels off the ground.
Old Aug 21, 2009 | 09:37 PM
atl8's Avatar
I have a set of the 2pc 56" Race Ramps. With the Mazdaspeed front bumper and Racing Beat Spring (.5 inch dop) I can barely drive up on them without scraping. They did not fit when I had H-Techs (1" inch drop in front), and I would end up moving the Ramps backwards instead of driving up onto them.
Old Aug 21, 2009 | 11:44 PM
Chris's Avatar
Turbo Member
thats because you are on coilovers, most likely lower then my car
