View Full Version : Which parking lights?
ddtran46 08-17-2009, 02:05 PM Hi guys. I am going to buy a pair of parking lights soon, but would like some inputs on these.
http://cgi.ebay.com/ebaymotors/RX-8-RX8-Parking-Lights-Super-Bright-9-LED-Bulb-Set_W0QQcmdZViewItemQQ_trksidZp4634Q2ec0Q2em14Q2el 1262QQhashZitem35a2eab211QQitemZ230366556689QQptZM otorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
or
http://cgi.ebay.com/ebaymotors/RX-8-RX8-Parking-Lights-Super-Bright-6-LED-Bulb-Set_W0QQcmdZViewItemQQ_trksidZp4634Q2ec0Q2em14Q2el 1262QQhashZitem439990dd8dQQitemZ290339216781QQptZM otorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Does anyone have any pictures of these installed? I would like to see the difference between the two.
I don't want the parking light to be alot brighter than the stock HID's.
08boostedmzda 08-17-2009, 02:16 PM You might take a look at the ones from rx8strakes.com. Rx8trakes is a forum vendor and have some really great products. I have their LED parking lights and love them.
http://www.rx8strakes.com/index.asp?PageAction=VIEWPROD&ProdID=415
ddtran46 08-17-2009, 02:22 PM Thanks. I think that Rx8strakes is the same seller as the ebay link I've shown.(it says it on the bottom of the screen). How much was shipping with Rx8strakes? You bought the 6 Led bulb set?
Aipex8 08-17-2009, 07:12 PM V-LEDS parking lights are a little cheaper, plus there is a 15% discount for rx8club members, plus they use .5 watt LEDs that are BRIGHT! For more info see my thread here:
http://www.rx8club.com/showthread.php?t=158590
A link to the lights I use:
http://www.v-leds.com/Interior-LED/DomeMap-LED/White-LED/V-LEDS-HID-WHITE-4-M-p5768269.html
My parking lights:
http://i234.photobucket.com/albums/ee35/Aipex8/Fogs/DSCF2151.jpg
ddtran46 08-17-2009, 09:16 PM Thanks for the link Aipex8.
I've read that the parking light can come loose and get stuck in the head light. Does this happen to the Rx8strakes bulbs? I'm close to buying it.
ddtran46 08-17-2009, 09:52 PM Anyone?
cyclone1208 08-17-2009, 09:58 PM yea i bought by pkg light bulbs from rx8strakes and they are a lil loose when u put em on.....just wrap tape over at the end to hold it tight and u should be fine
ddtran46 08-17-2009, 10:02 PM The bulb disconnect from the connector or is it still attached?
Aipex8 08-17-2009, 10:55 PM The VLEDS bulbs have a very thick base and are not loose in the socket.
ddtran46 08-17-2009, 11:53 PM The VLEDS bulbs have a very thick base and are not loose in the socket.
Ok thanks. I just bought the one you showed me.
ddtran46 08-20-2009, 09:13 PM Is there a way to install the parking lights without removing the front bumper?
Aipex8 08-20-2009, 09:24 PM You don't remove the bumper for parking lights. You should be able to remove the fuse box cover on the drivers side, and the ECU cover on the passenger side then reach in and you should be able to feel the back of the socket. Twist counter clockwise. There may be a DIY thread with some pics.
ddtran46 08-20-2009, 10:27 PM Thanks alot Aipex8
ddtran46 08-20-2009, 10:51 PM Just finished installing it and it took me less thank 30 minutes.
http://i345.photobucket.com/albums/p389/ddtran46/DSCF9089.jpg
http://i345.photobucket.com/albums/p389/ddtran46/DSCF9090-1.jpg
Aipex8 08-20-2009, 11:45 PM Just finished installing it and it took me less thank 30 minutes.
Sweet! Those look great.
cidvicious831 08-20-2009, 11:48 PM nice!!!
ddtran46 08-21-2009, 12:12 AM Aipex8..you bought your fog bulbs from the same seller correct?
Aipex8 08-21-2009, 01:12 AM Yep
Spinning Sushi 08-21-2009, 01:16 AM Just make sure you buy some quality parking lights or else the heat from the HID's will kill them. Happened to two of my super bright ebay sets, learned my lesson, and bought some PIAAs.
ddtran46 08-21-2009, 01:25 AM What is PIAA?
Spinning Sushi 08-21-2009, 01:27 AM Have you been living under a rock or something? :rofl:
PIAA is a brand, one of the best brands in automotive lighting.
Spinning Sushi 08-21-2009, 01:29 AM http://www.piaa.com/
ddtran46 08-21-2009, 01:51 AM Have you been living under a rock or something? :rofl:
I guess I have. lol
lopezian2004 08-21-2009, 09:58 AM Looks good man. V-Leds also has some fogs you can buy to match your parking lights and side markers. Just check out Aipex's "WOW these LEDs are freakin bright!!!" thread or whatever its called :lol:
Or you could just do an HID conversion or HID projector conversion like I did :wink2:
Both options look great
