Tokico D-spec extension cable is stuck
Old Aug 10, 2009 | 09:05 PM
Olorin2's Avatar
Okay, so I had my D-specs cranked all the way down to the hardest setting for about a month or so. I have the extension cables for the rear ones, and now the left rear cable adjustment **** is just stuck. I don't want to force the **** on the cable, because I'm afraid I'll break something.
Anyone come across this issue with the D-specs and the cables? The only way to get to the tops of the rear struts is to take them out, and I wanted to avoid that if possible. I'm just not sure how much force I should use to try and get the adjuster unstuck.
Thanks for any suggestions!
Old Aug 10, 2009 | 09:43 PM
cjkim's Avatar
^noob
i experience it sometimes, i just force it and haven't had problems yet
Old Aug 11, 2009 | 08:27 AM
BRODA's Avatar
Not yet famous
Take out your interior trim panel and spray some WD40 where the extension cable meets the top of the shock. That usually works on my JIC's.
Old Aug 11, 2009 | 05:30 PM
Olorin2's Avatar
It's pretty tough to get to the top of the strut, but I'll give it a try! Thanks.
Old Aug 19, 2009 | 07:16 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
I actually just installed a used set of D-Specs on my 8 last week. The guy I bought them from, another user on here, had some issues with his adjustment cable staying in the port. The short term fix was we crimped the steel braid and then taped the **** out of it.
Now, I haven't messed with them enough to know if you're going to break anything or not, but fluid has replacement adjusters for like 30 bucks if you do decide just to get new ones.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Jelliott5384
Oct 26, 2016 05:15 PM
vapor2
Jul 9, 2016 07:35 AM
Danield97
Oct 10, 2015 05:58 PM
RenzoRx-8
Sep 9, 2015 02:38 PM
