View Full Version : Spark plug wires/coils/plugs connection
tmak26b
08-06-2009, 11:59 PM
I am hoping not to lose the connection for the wires/plugs/coils. Just in case I did, can someone tell me which one is which?
<----Front of car Coil 1 Coil 2 Coil 3 Coil 4
<----Front of car T1 T2
L1 L2
Can someone tell me which wire goes where? I see two wires with the blue/green marking on it.
racerboy59
08-07-2009, 12:34 AM
look here - http://www.rx8club.com/showthread.php?t=31872.html
just to summarise.
The blue/green leads connect to the trailing plug (top 1).
The easiest thing is to replace them 1 at a time so you don't get lost. Remove all of them at once and hope you have a good memory.
I'm sure you will be fine anyway.
tmak26b
08-07-2009, 12:39 AM
So it looks like the coil lines up like L1 T1 L2 T2?
I just want to make sure. My car is still missing a tire, cant start it yet, so pissed
dozer
08-07-2009, 12:42 AM
yeah just replace em one at a time, its WAY easier, if you need help, look at for the DIY in the DIY section
Charles R. Hill
08-07-2009, 07:01 AM
Here is what is noted in the BHR Ignition System instructions:
"Step 2) Disconnect each of the four Mazda ignition coil wiring harness connectors and keep them in order, front to rear. Note the following; the coil sequence, front-to-rear, is L1, T1, L2, T2 and the coil trigger wires in each Mazda harness connector are green (L1), white (T1), yellow/green (L2), and blue/black (T2)."
FazdaRX_8
08-13-2009, 11:10 PM
so is the front rotor 1 and the rear rotor 2?
tmak26b
08-13-2009, 11:52 PM
yup
