Racing Beat Sway Bar Bushings Dry W/ No Grease?
Old Aug 2, 2009 | 10:17 PM
WTBRotary!'s Avatar
Drummond Built
After reading Expo1's DIY for installing RB Sways ( https://www.rx8club.com/showthread.p...y+bar+endlinks ) I found his other post about his RB Bushings being completely dry and making a horrid noise ( https://www.rx8club.com/showthread.php?t=65304 ). Could this be caused by overtightening the clamp that holds the bushing and pushes out the grease or is it just the grease in general? Is there any other type of grease that will not dry out like the grease supplied with RB's sways? Thanks
Old Aug 2, 2009 | 11:29 PM
normal. Drill and put in zerk fitting.
Old Aug 3, 2009 | 12:49 AM
WTBRotary!'s Avatar
Drummond Built
Im kinda young, explain to me exactly what you meant there Razz... because i have NO idea what that means...
Old Aug 3, 2009 | 05:46 AM
expo1's Avatar
He's as bad as Can
Did you read ALL the posts in the thread of mine you mentioned? If you did I don't see how you could have made the above post.
Old Aug 3, 2009 | 07:50 AM
Huey52's Avatar
Registered Zoom Zoomer
Zerk fittings are good, along with regular inspection/lube, when dealing with low cost urethane bushings. More costly rubber bushings are of course superior as far as noise, but do wear more quickly. Copper grease is a plus.
Old Aug 4, 2009 | 12:27 AM
WTBRotary!'s Avatar
Drummond Built
I read about your fitting but im still lost as to exactly what it is, i was making sure what type of grease to get as well as what a Zerk fitting is...
Old Aug 4, 2009 | 12:41 AM
any type of bearing grease will work
couple bux u can buy a huge bottle that will probably last the life of your car(and many car afterwards)
Old Aug 4, 2009 | 12:50 AM
WTBRotary!'s Avatar
Drummond Built
So Autozone would have it correct? and it doesnt have to be some urethane grease?
Old Aug 4, 2009 | 01:01 AM
Autozone has them.
They have it in one section, usually next to gear oils.
Just grab a tin bottle of Mobil1 Synthetic Grease. Its Red-ish in color, its cheap, and they last very long.
Old Aug 4, 2009 | 01:03 AM
WTBRotary!'s Avatar
Drummond Built
Alright man and for these Zerg fittings what are they? Ive looked at them in Expo's pics but still kinda lost... anyone have any good pics and info on how to use them and what they look like?
Old Aug 4, 2009 | 01:10 AM
Razz was talking about the metal clamps part.
http://wiki.answers.com/Q/What_is_a_zerk_fitting
Old Aug 4, 2009 | 01:16 AM
WTBRotary!'s Avatar
Drummond Built
So a Zerg fitting it just a cork like object that you can take out and use a grease gun or something like it to grease your bushings? then clog it back up?
Old Aug 4, 2009 | 01:21 AM
Jon316G's Avatar
Grasshopper
Umm... no.
A Zerk fitting is more like a one-way valve.
You insert the grease gun nozzle onto the fitting and pump the grease.
The grease goes in but can't come back out.
Old Aug 4, 2009 | 01:22 AM
Jon316G's Avatar
Grasshopper
http://en.wikipedia.org/wiki/Grease_fitting
Solidtrance
22
Sep 4, 2015 12:47 PM
Creto
Gulf For Sale/Wanted
24
Mar 27, 2010 11:54 PM
Creto
Mar 27, 2010 11:49 PM
hioctane
30
Nov 19, 2008 08:24 PM
