Loss of Power on hill?
Old Jul 31, 2009 | 04:30 PM
batangisip89's Avatar
i read another thread stating that if im going up a hill and i notice a drop in power that my cat is clogged...
but i can drive through hills fine and i have no loss in power, but if im at a light or at any kind of stop and on an incline my start is very sluggish.
also i have a check engine for a small evap leak if that makes any difference.
so my question is, are these symptoms of a clogged cat?
Old Jul 31, 2009 | 06:05 PM
EDZRIDE's Avatar
2005 White GT
Need some more information; year, mileage, and any work done to the engine. The small evap leak is probably the gas cap.
Old Jul 31, 2009 | 06:08 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yep........guessing gas cap as well, but would need the code for sure. Guessing the other issue is probably coil/plug time?????? Need the info as stated above.
Old Jul 31, 2009 | 06:49 PM
2005 GT, Bone Stock,
57,xxx miles
po442- small evap leak
Old Jul 31, 2009 | 07:03 PM
Old Rotor's Avatar
Has it ever been flooded? Did you get new? Are you using prem gas? When there is a loss of power does it sound different? Where do you live it's not listed? Is it heat related...only on hot days. How many miles on spark plugs and coils? Does it idle smooth?
Old Jul 31, 2009 | 08:18 PM
Old Rotor: i believe im the second owner, i had it for about a month now... i have never flooded it.
and yes i alwayz use premium gas, when there is a loss of power it just sounds as if its going to stall so i just keep revving it until it picks ups.
i live in NC, on a daily basis highs are around 90 an lows are high 70's, i dunno if its really heat related i do most of my driving during peak heat hours... so im not sure.
i have yet to change the plugs since my ownership... idle is pretty steady +/- 50ish, idles more roughly with a/c on but thats no shocker.
Old Jul 31, 2009 | 08:36 PM
KrylonFuzion's Avatar
Just say no to pistons
do you know when the spark plugs WERE changed? to be safe, they are to be changed every 30,000 miles. if they have NEVER been changed, your plugs are most likely very dirty.
Old Jul 31, 2009 | 09:46 PM
Old Rotor's Avatar
I agree the plugs could be the problem....
Old Aug 2, 2009 | 11:52 AM
Mazurfer's Avatar
At 57k, I'd change the coils/plugs/wires all at the same time.
Old Aug 2, 2009 | 12:40 PM
invasion08's Avatar
When my car was at normal operating temp and going up hill i could not go past 65 mph. The car would make the marbles in the can sound. I brought the car to the dealership and at first they thought the cat went again. The follow day later i was informed my car was getting a new engine. Mazda said when the car was at operating temp the apex seals would not seal correctly. Make sure you have the service manager test drive the car with you in it. I brought my car to the dealer when i was having the problem so they could see what i was talking about. If you leave the car overnight they will not notice a problem.
Old Aug 2, 2009 | 05:59 PM
thanks for the replies guys, ill probably get the wires, plugs, coils changed when i get payed.
i have no problems taking hills while moving, its at a stop where i feel the loss in power.
RevMeHarder
Jun 1, 2026 02:30 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
Emmanyei
Sep 19, 2015 11:12 AM
gnat42
Sep 16, 2015 08:47 PM
tgaffner
Sep 7, 2015 08:49 PM
