car remote problems? last resort
Old Jul 30, 2009 | 03:20 AM
sxe1215's Avatar
Question car remote problems? last resort
ive tried to reprogram the remotes as people say your car battery dying can cause the codes to be reset and no luck, followed the instructions on the diy https://www.rx8club.com/series-i-do-yourself-forum-73/diy-code-your-own-key-remote-43873/ completely and nothing... autozone's remote tester thing shows that both of mine have battery and put of a signal. mazda dealer says if reprogramming them dont work then the remotes could be bad (considering both of them are atleast putting of a signal). Anyone else have this problem or even better a solution? helpp me!
Old Jul 30, 2009 | 12:48 PM
Shijin-Kun's Avatar
Rotary Power!
i got the same problem with mine. Mine throw out a signal but its so weak the car wont pick it up. Since im so busy with work i havent had a chance to get these checked.
Old Jul 30, 2009 | 12:54 PM
rodjonathan's Avatar
silent assasin
i had this problem too! but i managed to fix it by reprogramming it took like 4 tries though ... are either of you goin to the meet tonight?
Old Jul 30, 2009 | 12:55 PM
Shijin-Kun's Avatar
Rotary Power!
theres a meet?
Old Aug 1, 2009 | 03:12 AM
sxe1215's Avatar
ill just keep trying this reprogramming, no rodjon your using the last pic (4th one) on that thread right? id assume so but just making sure im not retarded. also i wish i knew about this meet cuz id be there if i had checked this post. where was it at?
Old Aug 2, 2009 | 02:24 PM
Jab's Avatar
Jab
I had a similar problem. It would shoot the signal, but nothing would happen. I ended up buying a replacement remote($50). I have the switchblade kind, so the key part is separate from the remote, so I kept my key and didn't have to re-key.
Old Aug 2, 2009 | 08:13 PM
sxe1215's Avatar
but 2 remotes with the same problem? seems unlikely
dbarber
Jul 25, 2015 01:34 PM
Jvswan
28
Jul 23, 2015 09:02 AM
Str8lineJKing
Jul 22, 2015 04:19 PM
Belalnabi
Jul 17, 2015 07:48 PM
westgman
Good Guy/Bad Guy
Jul 15, 2015 11:18 PM
