Immobilizer question
Old Jul 27, 2009 | 01:08 PM
Daed's Avatar
If your key doesn't match the ecu anymore due to having to replace the keyset, will you still be able to power on the car to get odb info and basic functionality like lights? Or will it not even do that?
Old Jul 27, 2009 | 07:48 PM
04RX8man's Avatar
Rotary Powered Countryboy
As far as Iknow the PCM will not recognize that key and will not command anything to work/turn on....
Old Jul 27, 2009 | 08:05 PM
StealthTL's Avatar
Metatron
Lights work straight off the battery, so yes, they will work,
The ECU will power up, I'm pretty sure it will give codes, but defo won't run.
With new keys, only the Ford/Mazda 'dealership' computer can get it to run or accept new keys.
S
nferguson88
Oct 6, 2015 12:45 PM
jer2911
Sep 29, 2015 06:37 PM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
