alignment question
Old Jul 25, 2009 | 11:17 PM
Ka_RX-8's Avatar
CA alignment question
i went to mazda dealer they did oil change for me... a lot smoother ^O^
but i want to ask is..
they also do a free alignment inspection for me...
here is the report...
steer axle - 0.8 mpg
5.0 ft/mi
passed
rear axle - 0.8 mpg
-30.0 ft/mi
marginal
passed: up to +/- 15.0 ft/mi
marginal: +/- 15.0 ft/mi up to +/- 30 ft/mi
failed: over +/- 30 ft/mi
....so how bad is that?? is it serious problem?? or something??
i ask the dealer he said nothing really major don't really have to fix it....
Old Jul 26, 2009 | 12:38 AM
FazdaRX_8's Avatar
sounds like a lazy dealership in the first place....
Old Jul 26, 2009 | 01:19 AM
Ka_RX-8's Avatar
i mean i talked to the mechanic and i was watching him while he is checking and oil change the car....it looks fine, he said everything is good too....so..i don't know
Old Jul 26, 2009 | 11:44 AM
ken-x8's Avatar
Very odd units in that report. Do you know what the "mpg" stands for? I presume the ft/mile numbers are just a different way of expressing toe-in angles.
But there isn't enough data in that report. An alignment should check camber and toe for every wheel, caster for the fronts, total toe at both ends, steer ahead in front and thurst angle at the rear. Looks like all you've got is total toe at each end.
Personally I wouldn't be thrilled about any number that's marginal. If you've got good tires on the car and want them to last, it would be worth paying for a proper alignment.
Ken
Old Jul 28, 2009 | 07:19 PM
rotareriot's Avatar
good ole' wankel spanking
i just bought new tires for my car and a couple people have been sayin how they noticed my rear wheels having a bit of problems and that i need an alignment done, but i wanna make sure i dont get screwed on it for a good one. you guys know what to expect the cost of a total alignment being?
Old Jul 28, 2009 | 07:52 PM
Ken
Yep, that means the alignment goes out of wack every 8/10ths of a mile per gallon.
Old Jul 28, 2009 | 09:31 PM
ken-x8's Avatar
...you guys know what to expect the cost of a total alignment...
$70 to $150. Be careful about asterisks in the price. A few years ago I took my Honda to a Midas place where they had a big sign saying $90. When they brought the bill, it was $120. Honda was one of the "some models extra" cars, probably because of the flux capacitor.
Not sure what my local Mazda dealer's regular price is for alignment, but they always have a coupon for $90...no asterisk for the 8.
With new tires, you should get an alignment soon. And find a place that measures degrees or mm, not mpg.
Ken
Old Jul 28, 2009 | 11:53 PM
wtf is "mpg" doing in an alignment test ?
next is what? vtec y0 in the compression test ? VVT-i in vacuum test ?
hmm ... even if Im u, I would do the alignment somewhere else, most shop with Hunter equipment will do Alignment back to factory spec for maybe 80 bux.
gwailo
May 14, 2024 06:57 AM
nferguson88
Oct 6, 2015 12:45 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
