Check enigne light - code PO301
Old Jul 24, 2009 | 06:36 PM
derek54's Avatar
So a couple days ago after filling up with gas i noticed a high pitched squeeling noise coming from the engine.
then about 20 seconds later it started running really rough. check engine light started blinking. and the car was rumbling lots.
It didnt seem to have much power at all. (just barely running)
I pulled the code PO301.
which is "cylinder 1 misfire"
I've searched and heard that it could be the typical plugs/coils/wires.
I have new sparkplugs that i could put in. but i dont want to foul them and lose $100
any ideas on whats wrong? or what i should do?
Old Jul 24, 2009 | 06:38 PM
invasion08's Avatar
How many miles are on your coils and spark plugs?
Old Jul 24, 2009 | 06:40 PM
shaunv74's Avatar
Power!!
Purchase new ignition coils and wires as well and install it all at the same time. Coils are a common problem and go ~40K miles. They're about $30 each from the dealer and you need 4. If you can replace your spark plugs you can replace your coils yourself.
Old Jul 24, 2009 | 06:44 PM
invasion08's Avatar
I would also replace your spark plug wires, but thats just me. Remember to put a little anti seize on the spark plug threads.
Old Jul 24, 2009 | 07:46 PM
derek54's Avatar
Where do you guys suggest i buy the coils and wires?
I ordered my plugs from fluid motorsports. and the shipping and everything was great. but I'm wondering if theres a better wire set then the moroso one on fluid. or coils at a cheaper price somewhere?
Old Jul 24, 2009 | 07:47 PM
OnlineMazdaParts.Com
Finishlineperformance.com
or one of the forum vendors here.
You pick the shop.
Oh btw, just buy coils, thats all you need for now. trust me.
Old Jul 24, 2009 | 08:18 PM
Easy_E1's Avatar
You could always buy the BHR coil Kit. And not worry about them again.
We also have the MSD wires for stock applications as well.
Old Jul 24, 2009 | 08:33 PM
derek54's Avatar
yeah i was considering that.
the upgraded coils are a little too much money for me...
I just made my order from fluid motorsports.
Now i just gotta wait. I'll let you guys know how the install goes.
thanks for your help
Old Aug 1, 2009 | 09:07 PM
derek54's Avatar
so i installed the coils, wires and spark plugs today.
and... nothing. The car isn't starting. (it wasn't starting before too)
I'm lost... I dont know what it could be.
I tried pulling codes but nothing showed up.
Old Aug 1, 2009 | 09:12 PM
Jon316G's Avatar
Grasshopper
When you say the car isn't starting, does it attempt to?
If not, check your battery and connections.
If so, could be the starter or the engine is flooded.
I just read you 1st post and you mentioned a high-pitch noise.
Have you checked the belts for the proper tension?
If they comes loose, it'll make a high-pitch squeal.
Also, did you verify the coils are going to the correct plugs?
L1, T1, L2, T2
Old Aug 2, 2009 | 01:06 AM
derek54's Avatar
yeah I'm 99% sure everything was hooked up correctly.
I had another person helping me and i did it one by one. labeling everything.
I had the battery hooked up to a portable charger while trying to start it. even left it charging for quite a while and nothing. It turns over but doesnt seem to fire. everyonce and a while it seems like its about to start. but then back to the same dead sound.
Old Aug 2, 2009 | 03:10 AM
LytHka's Avatar
Doesn't sound like it, but try the deflood procedure.. disconnect e-shaft sensor, remove spark plugs, crank the engine until fuel comes out or doesn't and then squirt a little bit of washer fluid in there. Reassemble and try to start it.
Oh, and double check all connections to the coils/wires/plugs. The ignition system definitely caused the problem but there may also be flooding..
You can also have someone push start the car. Pop the clutch at ~20mph.. that usually does the trick.
Old Aug 2, 2009 | 02:02 PM
derek54's Avatar
Yeah I'm gonna go over everything later today. make sure connections are tight and they're all leading to the right place.
I might try a push start too.
Old Aug 2, 2009 | 03:44 PM
It could still be a dead battery. You never told us how old your car is and the milage.
Old Aug 2, 2009 | 04:40 PM
derek54's Avatar
2004, 95,000 km = 59k miles
I had the car hooked up to a battery charger while i was trying though. and left the charger on for two hours then came back and still nothing.
Old Aug 4, 2009 | 06:27 PM
derek54's Avatar
in case any of you were still wondering.
I got it all figured out today. got it towed to the mazda dealership.
they said one of the trailing and leading plugs were mixed up. I could've sworn i put them in right. anyways. they also said I need a new starter ($275)
and rotor 1 has no compression. luckily thats covered under warranty.
Old Aug 4, 2009 | 07:18 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
So you had reversed a leading and trailing plug......that's not good at all. Yikes!
I also assume the dealer knows that you did this?
Old Aug 4, 2009 | 07:54 PM
Jon316G's Avatar
Grasshopper
He said that rotor 1 had no compression, so that should mean a new engine is coming his way.
Any damage that could have been caused by mixing the plugs wouldn't matter.
I'm surprised the dealer isn't using the mixed plugs as an excuse as to why there wasn't compression on the rotor.
They usually try anything to not warranty the engine.
Old Aug 4, 2009 | 08:00 PM
Mazurfer's Avatar
That's where I was going with it!
I'm really surprised they didn't lay it all out right then and there.
Old Aug 4, 2009 | 11:38 PM
derek54's Avatar
When i told him that the car never actually ran with the plugs installed then he was ok with that.
they mentioned an upgraded starter was highly recommended cause my old one was going. i thought that was covered under a recall?
Old Aug 5, 2009 | 06:54 PM
Mazurfer's Avatar
I'm really not sure. It may have just been a TSB.
I think you said you were an 04............so hopefully someone will chime in on wether the ugraded started was a TSB or an actual recall.
xAgyex
Jun 3, 2026 03:47 PM
Olib1988
Aug 20, 2015 10:34 AM
Nisaja
Aug 6, 2015 01:27 AM
netrovers
Jul 20, 2015 03:32 AM
