Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Any cold airs in the DFW?
Old Jul 23, 2009 | 11:38 AM
Collier's Ride's Avatar
Lightbulb Any cold airs in the DFW?
The heat is tearing up my engine! Every 10minutes or so i'll be driving down the highway at 5,00RPMs or so and my over heating light will come on. So i'm getting an oil change even though its not due and i was thinking a lil cold air could be a quick fix? so anyone have a slightly used cold air for sell? Or i would even swap the stock intake for one if your thinking about selling your Rx8 so just hit me up with a price and we'll meet up and exchange!
Thanks,
Collier
Old Jul 23, 2009 | 11:48 AM
RyansRx8's Avatar
Brettward is/has a G
5000 rpms you going a steady 90 mph or something lol (assuming your in 6th)
Old Jul 23, 2009 | 11:50 AM
jmc23200's Avatar
Better flowing stock intake https://www.rx8club.com/showthread.p...y+stock+intake
Link + K&N drop in filter, Maybe remove the VFAD and replace your coolant.
Remove VFAD https://www.rx8club.com/showthread.p...ht=remove+vfad
Old Jul 23, 2009 | 12:35 PM
haha yuh around 80ish mostly but anywho ya ill be going and the overheat light will come on and i'll just drop it into neutral and it'll go off. then i'll put it back in 6th and keep on cruisin for another 10minutes and it'll pop back on.
Old Jul 23, 2009 | 12:39 PM
shaunv74's Avatar
Power!!
You should find out what the overheat light is coming on during Highway cruise. You should have plenty of airflow. That's not normal. Even in Texas.
Don't spend money on an intake to fix a cooling problem.
Old Jul 23, 2009 | 12:53 PM
Lord ET's Avatar
Is that a bike rack?
Check your engine coolant levels?
Old Jul 23, 2009 | 12:54 PM
Thanks JMC before i leave work today im going to remove the flaps from the inside of my stock intake and maybe that'll be the quick fix im looking for. Then when i get home im checking coolant levls and oils fixins! preciate your help guys.
Old Jul 23, 2009 | 01:27 PM
jmc23200's Avatar
It might just be the coolant is low or its a poor mix. I would flush and replace the coolant. It's easy and cheap. Here in MA, I use a 50/50 mix and I don't have any issues. The only time my coolant light came on was when I was revving the **** out of my engine in neutral at my old work. Some people wanted to hear it.
Old Jul 23, 2009 | 01:33 PM
haha well dude i just went out into the parking lot with a pocket knife and pulled my intake right on up and got rid of those flaps! then when i put it back in i started to check and see if everything was sconnected properly and ect. when i noticed a cracked black tubing coming from my intake...I saw there had previously been black electrical tape around but an un covered part was cracked. so i taped it and reved it up. i can definatly tell the difference! and my idle is below 1 but not shakey. how do i reset it? i tried the 20 brake pump thing but it didnt work :/ i might jyst drive the 100 miles to break it in. but i think this was the fix i was looking for. and agin i definatly heard a difference
Old Jul 23, 2009 | 01:41 PM
Alexb's Avatar
desperately needs a drop
Not sure what that light looks like. But my coolant light was coming on for a while at high highway rpms in june. I added more coolant and was good as new.
Old Jul 23, 2009 | 01:52 PM
Grungepup's Avatar
Oilfield trash
you might want to have your coolant sensor checked... its a known problem
Old Jul 23, 2009 | 02:27 PM
i found a cracked tube leading from my intake to the engine im pretty sure thats what it was. but ill give feedback after i cruise around for a few days and see how the removed flaps on the inside of my stock intake goes. im excited to see if i hear a difference which i already have but thats just a lil taste of what im looking for. I'll check my fluids this weekend and get back atchall asap
Old Jul 23, 2009 | 03:25 PM
jmc23200's Avatar
The cracked tubing from the intake should be nothing more then a vacuum line, I think. This should not effect your coolant at all.
Old Jul 23, 2009 | 03:34 PM
alright ill check my coolant thanks if thats not the fix ill get back at yall
Old Jul 23, 2009 | 03:46 PM
shaunv74's Avatar
Power!!
If you don't have a bad coolant sensor and you aren't low on coolant and your cooling system is working as designed and your car really is overheating You should get these.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/finally-oil-cooler-fan-kits-178918/
Old Jul 23, 2009 | 03:49 PM
shaunv74's Avatar
Power!!
Another thread with some PHX people's suggestions.
https://www.rx8club.com/series-i-trouble-shooting-95/car-doesnt-do-well-heat-177837/
Old Jul 23, 2009 | 04:16 PM
thanks for all you help i just went out to the parking lot to check my fluids and what do ya know! my coolant looks a lil low lol but theres still plenty im just gunna get a new mix and everything will be back and operational soo enough!
Old Jul 23, 2009 | 05:09 PM
Lord ET's Avatar
Good Luck!
Old Jul 23, 2009 | 10:10 PM
deadphoenix52's Avatar
meh.
coolant. the trip to and from lubbock is 330 miles of 80+mph in texas. the car can handle it just fine.
mdl0209
May 23, 2019 05:46 PM
Danield97
Sep 30, 2015 05:59 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
