Question about leaks under the car
Old Jul 22, 2009 | 06:20 PM
JinDesu's Avatar
went back to srsly broke
Where does the AC condensation dripping occur, and where do coolant leaks occur under the car? I noticed my car was leaking today, and it occurred next to the catalytic converter. I couldn't tell if it was water or coolant (I assumed water as it was clear and not colored), and I didn't know how to check the difference.
I have some pictures of the spot, but I think they are waaaay too obscure. It's pretty damn hard getting a picture under there...
Old Jul 22, 2009 | 06:28 PM
04RX8man's Avatar
Rotary Powered Countryboy
well if the coolant overflows it will be basically straight down from the belts since the fan's are angled etc etc...unless you have a leak from the block which i doubt that.....as for the evap I'm not 100% sure on the location of the evaporator but should be about straight down from the dash/firewall...best bet would be get a white shop towel/paper towel and soak it up and see if it's greenish or clear....not if you happen to have straight water for coolant this wont' work....sounds like evaporator dripping so you're fine
Old Jul 22, 2009 | 06:30 PM
JinDesu's Avatar
I'll try the paper towel method tomorrow or so. It was confusing to me because I can't see under the car very well (I need to buy a damn jack). My search of the forum led me to either coolant leak or AC condensation, but none of the threads mention where those leaks were at.
Old Jul 22, 2009 | 06:39 PM
04RX8man's Avatar
well coolant leaks usually are gonna b at the radiator/resivoir which is the front of the vehicl and the evap. is going to drain somehwer around the firewall....
JinDesu's Avatar
Gotcha, thanks.
Old Nov 27, 2009 | 01:50 PM
meskism's Avatar
Upon rotating my tire today, I noticed a fluid puddle underneath my car! Pulled the car out and it was green in color!!! Dam radiator fluid is leaking! I went under to see where its coming from couldnt really see anything! Went under the hood and I see a hose and it looks of green corrosion. Its going into what I think is the thermostat. There is a collection of fluid to where the hose is going into. I need some words of wisdom. Ultimatley I would like to avoid going to the stealership and avoid getting it without vaseline!!!! HELP!
Old Nov 27, 2009 | 09:25 PM
kersh4w's Avatar
Hit & Run Magnet
maybe you could find someone in your hometown to do a flushing of your coolant...
Old Nov 27, 2009 | 09:49 PM
Cvzrx8's Avatar
the a/c dripping is by the transmission/cat, weird spot but i saw it when i was under my car lol.
Old Nov 28, 2009 | 11:39 AM
EDZRIDE's Avatar
2005 White GT
Pressure test the system; you'll spot the leak quickly!
You could also try the "taste" test; antifreeze has a sweet taste.
mr. GrandGame
Sep 9, 2025 10:41 PM
Jesus Martinez
44
May 6, 2025 08:09 AM
9krpmrx8
Nov 5, 2015 11:45 PM
marc2820
Jul 26, 2015 10:47 PM
