AC Amplifier Question
Old Jul 21, 2009 | 03:30 PM
adamcoley's Avatar
I have a 2004 that is not under warranty anymore, as of about 2 months ago. I found a TSB that pertains to a problem that I am having with the AC system, fluctuating from cold-cool-cold when the AC system is on. The TSB calls for replacing the AC amplifier. I called parts to see how much this part is because I was gonna replace myself, and they told me that it is 614 bucks!!! Can this be true?? Does anyone else have this problem? Is there anything that I can do to remedy this without spending 600 bucks? Help!!!
Old Jul 21, 2009 | 03:40 PM
EDZRIDE's Avatar
2005 White GT
There are several threads on this topic that answer your questions; please use the search function.
Old Jul 21, 2009 | 04:36 PM
expo1's Avatar
He's as bad as Can
You can call / PM Mazmart and see how much they would sell a used one from a newer 8.
Old Jul 21, 2009 | 05:28 PM
Or check the junk yard.
All AC go from hot to cold. This is normal on the RX8. Search and you will find this out.
Old Jul 22, 2009 | 05:47 PM
adamcoley's Avatar
Thanks for the help....or lack thereof. I'll go search somewhere, instead of someone who knows a possible solution, answering the question that I asked.
Old Jul 22, 2009 | 05:56 PM
Socket7's Avatar
ಠ_ಠ
Sounds completely normal to me.
My AC, from the day i bought the car with 100 miles on it, has always been somewhere between tepid and cool when sitting at idle, and ice cold when moving at highway speeds. I don't think the condenser can work very well when shoved in front of the radiator like it is, soaks up the heat from the rad while you're idling leading to less then cryogenic output. Especially if only one of your radiator fans is going at the time.
Thats my theory anyways. You could always wrap your AC lines in that mylar heat reflective junk if you don't like my theory. Lots of people have done that. Some even say it made a difference.
You bought a sports car, not a Cadillac. There are going to be compromises for performance.
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
