Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
sensor missing???
Old Jul 20, 2009 | 11:03 PM
Rotary_Guy's Avatar
Loud enough for ya???
sensor missing???
so i took my intake out to do the tb bypass, and noticed that the large "goldish" clip on the intake had nothing clipped to it, and a pretty detailed search revealed nothing... So what is this sensor and what's it connected to? the other smaller sensor, which i assume to be the vfad controller, is also missing one vaccum hose. I'll post up pics tomorow if it'll help.
Old Jul 20, 2009 | 11:05 PM
Jon316G's Avatar
Grasshopper
If the clip is on the air box, then its probably the clip that holds the VFAD vacuum chamber.
And your VFAD "controller" is probably the VFAD solenoid.
Did you get this car used?
Someone might have removed the hoses for the VFAD and just left the solenoid in place.
If this is the case, you should have the nipple behind the throttle body capped too.
Pics will help clarify this.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Evan Gray
Nov 24, 2015 01:00 AM
