engine dies out after high rpms
Old Jul 17, 2009 | 06:29 PM
dozer's Avatar
on his 3rd rx8
alright guys i ran into another problem...
i redline 1st then go into high rpms in 2nd then throw it into neutral, then the car shuts down...
any suggestion as to what the problem might be? i just changed out the coils the other day, my plugs have about 2.5k on them...im lost as to what it could be.
Old Jul 17, 2009 | 06:33 PM
invasion08's Avatar
Check your battery terminals and see if they are tight. I loose connection can cause weird things to happen
Old Jul 17, 2009 | 06:34 PM
xun4gvn4everx's Avatar
True love is blue x2
F-ing n00b!!!!!! Use the search button!!!!!!!!!!!!
Old Jul 17, 2009 | 06:35 PM
But seriously, I would question the coils. put the old ones back on and see if the same problem is there.
dozer's Avatar
on his 3rd rx8
thats the first thing i checked...theyre on there tight as possible
Old Jul 17, 2009 | 06:36 PM
dozer's Avatar
on his 3rd rx8
first time it happened was with the old coils, i thought buyin new ones would solve it
Old Jul 17, 2009 | 06:38 PM
invasion08's Avatar
strange so it only does this when you redline and not during daily driving?
Old Jul 17, 2009 | 06:42 PM
Well, we know it is prob not the coils unless your old ones were bad and you bought bad coils (which is highly unlikely). Is it throwing a CEL?
invasion08's Avatar
Lets start simple, i would pull the plugs and take a look at them. Bad coils could have fouled them. It could be either electrical system or in the fuel system.
Old Jul 17, 2009 | 06:43 PM
invasion08's Avatar
Try cleaning the MAF sensor
Old Jul 17, 2009 | 06:45 PM
+1 to pulling the plugs. I've heard of bad coils f-ing up the plugs
dozer's Avatar
on his 3rd rx8
yup. not even redline, just anything above 4.5k ish and then i throw it into neutral...then it dies out
could it be my battery?
Old Jul 17, 2009 | 06:46 PM
dozer's Avatar
on his 3rd rx8
k gonna clean out the MAF right now
Old Jul 17, 2009 | 06:47 PM
It can't hurt to check your battery, but I doubt it. whens the last time you replaced it and do you have problems initially starting the car? It sounds more like a firing issue do to plugs, lack of fuel, incorrect air to fuel ratio, etc...
Old Jul 17, 2009 | 06:52 PM
invasion08's Avatar
is the clutch pushed in or your foot off the clutch
Old Jul 17, 2009 | 06:56 PM
dozer's Avatar
on his 3rd rx8
my foot off the clutch, and the gears in neutral, i just dies out if i come off of high rpms
dozer's Avatar
on his 3rd rx8
ill order new plugs next friday, i am running a catless pipe with no tune, but it never had a problem before, ive been running catless for about 6 months now
Old Jul 17, 2009 | 06:58 PM
dozer's Avatar
on his 3rd rx8
note: car acts fine is if i down shift and rev match then throw it into neutral in 2nd gears at about 3k RPMs
Old Jul 17, 2009 | 07:08 PM
COuldn't hurt to get the codes checked.
Old Jul 17, 2009 | 07:15 PM
dozer: check your MAF screens.
clean throttle body?
Old Jul 17, 2009 | 07:21 PM
dozer's Avatar
on his 3rd rx8
got em checked already, only thing was my cat (no cat) and my gas cap...
jedi just did that, seemed to help but the maf seemed a lil loose, john tighten it and it help at high rpms, went around the block it died once, as appose to dieing all the time...hmmmmmm
Old Jul 17, 2009 | 07:23 PM
Was it loose because of the housing or it had jiggled itself loose? Seems like you have narrowed the problem down to probably the MAF sensor or the housing.
Old Jul 17, 2009 | 07:25 PM
clear the ECU and go for another drive
^+1 good call
dozer's Avatar
on his 3rd rx8
im assuming the housing, if you search youll find atillas youtube video of my drunken intake install, so im hoping all the drunk fcks installed it wrong and the housing isnt sitting right...im gonna try to tighten it more
